difference between spoon adj. and non-adj damper
Old Nov 1, 2002 | 01:38 PM
citanest's Avatar
New User
Default difference between spoon adj. and non-adj damper
Are there any differences between the 2 other than one is adj and one is on-adj?
In terms of piston size, compress, rebound, overall performance, reliability etc?
Also, do the non-adj mate with straight spring, how will the height be look like for the non-adj?
Old Nov 1, 2002 | 03:02 PM
citanest's Avatar
New User
Default Re: difference between spoon adj. and non-adj damper (citanest)
Old Nov 1, 2002 | 05:30 PM
citanest's Avatar
New User
vender?
Old Nov 1, 2002 | 05:33 PM
Reid's Avatar
Global Moderator
The non-adjustable version is the "sports" version while the adjustable version is more of a "race" version.
The non-adjustable dampers are made to be used with OEM style springs, not straight springs.
Old Nov 1, 2002 | 08:43 PM
rodimus's Avatar
Default Re: difference between spoon adj. and non-adj damper (Reid)
you can adjust the adjustable ones and you cannot adjust the non adjustable ones.
Old Nov 1, 2002 | 09:26 PM
sneakychaos's Avatar
Default Re: difference between spoon adj. and non-adj damper (EVOL)
what he said. atleast it sounds like the smartass answer to say.
yes im drunk. yes im ok with that. go buy some APC's. they rock. nadz.
Old Nov 2, 2002 | 02:24 AM
RagingAngel's Avatar
I'm assuming this is Rex?
Piston size is the same because Spoon believes stock is best in this case. Rebound will be less aggressive than the threaded coilover setup and it will be more "reliable" because it is valved less aggressively. Their sport dampers are designed to work in conjunction with their sport springs....rated at 6.5kg/5.5kg both of which are progressive. The sport dampers are also the stock length while the coilovers are short stroke.
No...non adjustable must use regular type lowering springs. As they feature factory perches. They also lower -20mm from stock ITR height.
jlh22179tx
Suspension & Brakes
Mar 19, 2007 09:34 AM
mugenracer
Feb 8, 2004 07:46 PM
01-1293
May 16, 2002 11:06 PM
typerlover
Aug 26, 2001 05:13 AM
