1992 Sedan D16Z6 to D15Z1 conversion: Which exhaust piping to use?
I'll be converting a '92 CDM Civic EX-V to accept a D15Z1 motor. However, before it goes anywhere, it needs a replacement B-pipe. Since there is no such thing as a VX sedan in North America, I don't know enough about exhaust stuff to know if I should replace it with the pipe that's used for an EX/EX-V sedan, or one that's used on an LX, which might be more appropriate for the D15Z1 engine? These are different part numbers, I think one is narrower, but the lengths are the same? What would be the difference, and the loss or benefit of each option?
Thanks.
Thanks.
Will you be getting the VX cat converter? You should be able to still use your current exhaust with this motor, its just the cat that is specific to reduce the high nox this engine produces.
Post #37 the OP talks about which exhaust he used for his conversion. Pics in post #38.
1993 Honda Civic VLX
eH.
eH.
Yes, I have the VX cat converter ("maniverter") and the VX A-pipe. On a D15Z1 sedan, this would normally mate directly with a B-pipe, but this is where the cat is on this car - need to replace this with a straight-pipe or gut a cat.
eH.
eH.
This was good advice, thanks. DX, etc., 96-00 pipe has no cat and fits perfectly under the 92-95 vehicle. Used one at yard was $15, can't beat that. Only difference of note was there is only one hanger at the mid-point on the stock 96-00 unit vs. the 92-95 has two. Length, dimensions, etc. were all compatible / identical.
mikej94civex
Jan 12, 2010 03:21 PM
Twilight
Aug 25, 2005 01:11 AM
