H4 hid high/low little halogen bulb not working
the hids come on fine every time like they should as its on the low beams.
When i flick my high beams on for the little halogen bulb to come on nothing happens.....
What do i do to fix this do i rewire the lights some how making the hids come on with the high beams. and
the little hallogen bulb come on with the low beams??????
its a opt7 35w 10k H4 High/low kit by the way to
Hey Rodney Williams
Take a look at the HID bulb plug in the back . Where is the Power wire for the High beam going . Is it on the left or the top ? Try switching the top and left wire to see if this will help .
u mean like cutting the wires on the plug and switching the positive and negative ?
The Plug can be moved without cutting . The prongs can be removed with a tiny flat head screw driver and they can be relocated.
by switching the top and the left wire, it will test to see if the high beams will be on once your turn ON your headlights . With power running to the little high beam bulb . you will then treat that bulb like any other filament bulb.
when i turn my low beams on only the passanger side hid comes on and when i flick my high beams the driver side hid comes on i need help i want hids..... i checked what u sad to do there right and some times both of them come on but the passager side one the hid and and halogen bulb come on and it flickers alot and when they power on you can hear them make a spark noise like a pop idk wtf is going on.............. i have even fliped the little plug ins stilll dont work right
itsmejto
Jun 22, 2008 04:11 AM
