Got my ZC Swap Running G00d
Old Nov 1, 2002 | 01:13 PM
ScottEK's Avatar
Default Got my ZC Swap Running G00d
Today I replaced the coolant line that busted and after that let it idle for 20+ minutes, fans kicked on twice. Idle sounds nice, I'm going to get a timing light this weekend I think I should have it set at 18 BTDC. I still might replace my timing belt, I bought one at NAPA and it was kind of loose but it seems to have tightened up after the long run today. My mainshaft bearing is still a little noisy but I guess I'll just ride on that. Does anyone else have problems with their swap shaking the entire inside of the car? Guess its just the price to pay.
Old Nov 1, 2002 | 04:56 PM
d-wreck's Avatar
Default Re: Got my ZC Swap Running G00d (beta13)
i mine vibrates, just because i didnt bend the rear xmember done enough on a b-series. but on your loose timing belt check the torque spec on the tensioner bolt again because your suppose to turn the motor over a few times then torque it, its probably a little loose, from what im guessing, check what the manual says for deflection spec on the belt. skipping a tooth isnt usually a good thing especially since it happens when you dont want it to.
derek
Old Nov 1, 2002 | 05:53 PM
ScottEK's Avatar
Default Re: Got my ZC Swap Running G00d (d-wreck)
Yeah I'm guilty of that, I missed the part about re-tensioning the timing belt where you move it back three teeth. I'm doing a compression test tomorrow and if it checks out good I'll probably throw a Honda timing belt on it just so I wont have to worry about it. To just retension I'd have to take it apart to the point where I could change belts anyways.
Old Nov 1, 2002 | 05:54 PM
ScottEK's Avatar
Now that you mention it, my header is in contact with my front cross member, I have a DC 4-1. I'll be getting rid of it this winter so hopefully that will clear up my shaking problem. Also my exhaust is catless with a huge hole in the muffler, like 3 inch diameter hole, that might be shaking it a little too.
Old Nov 1, 2002 | 06:51 PM
Rydaddy's Avatar
Good god....thats huge man.
Old Nov 1, 2002 | 09:55 PM
spettinger's Avatar
Default Re: Got my ZC Swap Running G00d (Rydaddy)
i don't remember my ZC shaking much, seeing as it used the stock mounts. my guess is the header touching the crossmember. my sawzall owned my crossmember to clear a 4-1 for the B16.
Old Nov 2, 2002 | 06:17 AM
ngkplugs's Avatar
hahahahahaha
Old Nov 2, 2002 | 06:18 AM
ScottEK's Avatar
Default Re: Got my ZC Swap Running G00d (ngkplugs)
I'll take a picture of it tonight, kind of makes the car sound like a hemi
Old Nov 2, 2002 | 03:51 PM
BigDaddyRich's Avatar
My ZC swap went smooth nothing vibrated AT ALL ... ran and idled like stock.
gokblok
Aug 1, 2013 04:20 PM
crix351c
Feb 27, 2005 10:30 AM
kicker1_solo
Feb 25, 2005 01:53 PM
sporty240
11
May 3, 2004 01:48 PM
sporty240
Apr 30, 2004 02:25 PM
