what truely adds hp-increases hp-speed?
what really adds hp? what really adds speed? f22a1 engine stuff? has to be naturally aspirated need help. has factory header on it now, 91 accord ex.. what really makes a difference?
A6 is mostly the same engine, larger cam, windage tray, different intake manifold and of course the ECU. That makes 15HP more than your engine.
Slap on a turbo and you should be able to gain 40-50HP with mild boost and good tuning.
With regards to speed aspect your wheels you run make a huge difference. Lighter skinnier wheels mean faster road speed. Then on that subject bulk weight in the car can be a difference. Replacing parts for lightweight and removing unwanted accessories like a/c, rear seats, spare wheel etc
We race on a dirt oval against the mustang 2.3s with the solid lift heads-long rod bottom ends I wanna outrun them, every week we get our a"" handed to us weekly due to them murdering us, we have even went from a 15 inch tire and wheel down to 13s and still getting murdered
the 4th gen prelude S came with a f22a1 rated at 135hp, the IM and exhaust are the same so the only difference i heard is the ECU heard this claim on cb7 forum and the benefit is small but with some a6 upgrades you get more out of it. (correction 10+ forgot the f22a1 accord is rated at 125hp sorry)
No. But it will with one of these:
Evolution F2H Intake Manifold Adaptor | 29611
Also, a K-series intake can be made to fit with relative ease, too. Takes a bit more fab, but it can be done and K20A2 intake manifolds are cheap and pretty efficient to 7500ish RPM.
Im curious as to what size throttle body& what size injectors to run. Considering engine is stock other than the fact im changing intakes-ect May also consider changing the Cam over to a A6 and that ecu..
H22 SKUNK2 MANIFOLD GO WITH 70MM and bore out the intake to the same. the cam, look into webcams which is the manufacture that use to make regrinds for bisimoto.
joshhulebak
Honda Civic (2001 - 2005)
25
Jun 10, 2014 08:42 AM
Track rat
47
Apr 24, 2005 01:28 PM
aasaa666
Mar 20, 2005 06:01 PM
we have open rules other than no nitrous-turbo-supercharger, limted to a sohc only we aren't aloud the dohc engines
