B20v NOS - can a Cast Piston take it?
Old Oct 15, 2014 | 07:24 AM
KeeganBuilt's Avatar
Default B20v NOS - can a Cast Piston take it?
whats up HT! I posted in another part of the fourm and no dice.
My last b20v setup made 240 stock bore stock sleeves buddy club spec lll's. Good set up. (RS Machine ITR Reps).
Now I got a css werx block with 85 bore with itr reps pro2's. \
My question is how much NITROUS can a cast piston take? I cant find the answer anywhere. I know multiple variables are played but just need a round about answer. Looking to spray this b**** about a 120 shot.
Hoping for 250 off the bottle and around about 350-400 on the bottle.
Thanks
Old Oct 15, 2014 | 11:20 AM
94dxcoupe's Avatar
Default Re: B20v NOS - can a Cast Piston take it?
As long as you spray enough fuel, then the pistons don't matter much. Your problem is going to be if you run lean - It will heat the piston very quick and score the cylinders and possibly break ring lands...
Your main concern should be the dinky stock rods. Hopefully you atleast installed some ARP rod bolts.
Old Oct 16, 2014 | 07:57 PM
Oh my bad I forgot to say I have rods, I already knew that. So what could I use to prevent heating quickly
kornerk12
Jan 11, 2006 10:19 AM
96tegls
11
Nov 17, 2004 12:55 AM
