FS: 88 GXL - Built Small Block Chevy bored out - Comp/Moroso/Corbeau/Holly...
Love this car and it's been a lot of fun but unfortunately I just don't get to drive it that much and I could use the space in the garage. Always gets a lot of looks and the exhaust sounds great. There isn't much on the road that compete with a 450hp V8 coupled with the low weight of an RX-7 as well as the awesome weight balance you get with that chassis. It is road legal and it is currently insured & registered.
Overview:
* Year: 1988
* Make: Mazda
* Model: RX-7
* Trim: GXL
* Title: Clear & physically in hand
* Transmission: Manual (5 speed) GM T5 World Class
* Engine: Chevy Small Block V8 (bored 0.40" over)
* Accidents: None
* VIN: Available upon request
* Price: $3,500 OBO
History:
I originally purchased this car from a Mazda technician in New Jersey in 2009. Since then, it has not seen rain, snow, etc. It's been garage kept with the cover on it unless I was taking it out for a drive. I use the car for Sunday drives and also for auto-x. I haven't put more than 500 miles on it since I've owned it since it's only been taken to car shows, sunday drives, and auto-x events. It gets an oil change yearly since I never go many miles with it. A majority of the work done to the car was done by the prior owner. I have changed out the suspension from KYB adjustable shocks & springs to fully adjustable coilovers, stripped the interior, added the racing seat, battery box, etc to make it work better for my needs on the auto-x course.
The body of the car has 224k miles on it but the engine & trans only have 5k miles on them. The suspension has under 500 miles.
The car was re-painted by the previous owner (used to be white) and that was when the flame paint job was added.
Modifications:
* Chevy 350 Small Block bored 0.40" over
* Keith Black Hyperutetic pistons (11:1 compression)
* Vortec heads with:
** Screw in studs
** Larger springs
** Larger exhaust valves 1.94 1.60
** Ported
** Comp Cams Extreme Energy Cam 523 525
** 1.5 roller rockers
* Holley 650 double pump carb
* Holley manual choke
* K&N air filter
* Aluminum rpm air gap intake
* Full msd ignition system including distribtor down to plug wires
* Grannnyspeed shop kit for v8 (solid engine mounts)
* GM T5 WC transmission
* Centerforce clutch dual friction
* Fidenza aluminum flywheel and trans blanket
* Energy suspension bushings
* Drag radials in rear new tires up front
* Auto Meter Gauges for water,oil and monster tach
* Computech EGT gauge
* Turbo II Rear
* Stainless Steel Brake Lines
* Megan Racing 32 way Adjustable Coilovers w/ camber plates
* Ron Davis Radiator
* Thermo-tec spark plug wire sleeves
* Corbeau Driver's Seat
* Taylor aluminum battery box
* ATE racing brake fluid
* Moroso switch panel
* Moroso radiator caps
* Summit Racing vacuum canister
* Line locks
* No A/C
* No P/S
* Straight water with water wetter is used in this car since it lives in the garage and doesn't come out in cold weather. Note: If you are going to store the car outside or use in cold weather, you need to flush & fill with 50/50 anti-freeze & distilled water.
* Mostly stripped interior
Extras:
* Custom car cover (can be used for outdoor use if you so choose)
* Set of 4 wheels with Hoosier A6 tires
* Set of 4 wheels without tires mounted
* Spare Hoosier A6 tire (not mounted on a wheel)
* Passenger seat (OEM in case you want to move the battery box)
* Weld in roll cage
Issues:
* Some dings & scratches from being a car from 1988 (see pictures)
* Exhaust leak (off driver's side header)
* Gas gauge works but 1/2 tank is empty (new sender so it's likely the gauge)
* Sunroof needs to be opened manually
* Dent behind front fender in front of door
* Corbeau seat was bought used so it's sun faded from the guy I bought it from
Disclaimers:
* The vehicle is listed for sale locally as well.
* I'd prefer to not ship the car but if the buyer handles it, I can work with you.
* No joy rides or dreamers. Test drives are available for serious buyers who bring cash. Lets not waste each others time.
* Sold as is, where is. No warranties expressed or implied.
* I have feedback that can be provided to you for other forums as well as from ebay & paypal as well. I know I'm a lurker on this forum.
If you have any question about the car, please feel free to contact me via PM.
Thanks,
Chris
Overview:
* Year: 1988
* Make: Mazda
* Model: RX-7
* Trim: GXL
* Accidents: None
* Price: $3,500 OBO
History:
Modifications:
** Screw in studs
** Larger springs
** Ported
* K&N air filter
* Turbo II Rear
* Line locks
* No A/C
* No P/S
Extras:
* Weld in roll cage
Issues:
Disclaimers:
Thanks,
Chris
MyWhiteCivic
Nov 8, 2014 05:35 PM
