p0113,116
Old Oct 13, 2014 | 05:45 PM
Kevin82's Avatar
Icon3 p0113,116
Hey HT
I have a 1996 civic ex M/T. I have been losing my mind over this no start issue. The CEL cam on and told me, IAT and ECT sensor. So I replaced both of them ran fine one day then the next, CEL back on again. I cleaned the FITV in the interim (just an FYI).
Basically what I am asking is this. All the CEL codes I get come from the "D" connector in the ECM, is it possible to have a short somewhere? I have tested resistance at IAT and ECT sensors.. I am losing my mind.. Any suggestions would be awesome!!
I have checked the g101 ground, as well as all other grounds.. Can not seem to find any opens.
Live Data reads
IAT -40
ECT -4
TPS % 98.9
Map 7.3
Thank you
Old Oct 13, 2014 | 06:26 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: p0113,116
Wait, your live data reports the TPS at 98.9%, with the car not running? That...doesn't make sense.
Is your car a no-start no-crank, or a cranking no-start?
Old Oct 13, 2014 | 06:52 PM
Former User's Avatar
Reset the ECU. Crank engine for 30 seconds. Pull codes. Post them.
Old Oct 14, 2014 | 04:30 AM
Kevin82's Avatar
Sorry.. I should have stated it runs, then I shut it off, won't restart, has to wait for IAT to "cool" down.
I reset the ecu and the codes that came up IMMEDIATELY today were..
p0113
p0118
p0123
Also today the temp gauge didnt work.. All sensors plugged in, cannot see any breaks in the harness...
Thank you again
Old Oct 14, 2014 | 09:20 AM
Kevin82's Avatar
I also probes the "D" connector at ecu as per Honda manual. Got proper voltage. Just an update
Old Oct 14, 2014 | 09:41 AM
tony_2018's Avatar
Fish Twig
All of these codes point to a wiring issue. You have a wiring crossing into either the ground or to each signal wire going back to the ecu.
Old Oct 14, 2014 | 11:45 AM
Kevin82's Avatar
Should I start at the c115 connector?
Old Oct 14, 2014 | 01:52 PM
Nope
Old Oct 14, 2014 | 03:31 PM
Kevin82's Avatar
What do you suggest then RonJ?
Old Oct 14, 2014 | 03:34 PM
tony_2018's Avatar
Fish Twig
I think its best to start start from one sensor and trace the wires back to the ecu. And FYI 96 ex civics never came with an FITV.
Old Oct 14, 2014 | 03:40 PM
joey1320's Avatar
Find the wiring diagram and perform both a resistance test and a voltage drop test for every wire. You can decide which sensor to start with.
Old Oct 14, 2014 | 04:04 PM
Kevin82's Avatar
I thought the same thing!! Well this vehicle had one. Clearly the guy before me jacked that all up. I ran test at the sensor for the TPS. All test came back to spec. I probes at the ECU for the IAT that came back to spec. Looks like it is time to trace some wires. Car ran clean today. Noticed when I moved the main barness under the Intakr, everything on my live data chaned. Went from 73deg at IAT -40 when wiggled that harness. Does ground come internal at PCM for the IAT?
Old Oct 14, 2014 | 04:11 PM
joey1320's Avatar
The fact your data stream changed while shaking the wires tells you there's a wiring shaffed/broken/melted or such. Time to open up the wire loom and look for obvious signs of damage.
Old Oct 14, 2014 | 04:14 PM
Kevin82's Avatar
Agreed Joey. I will keep you all posted. I can access those from underneath right? I don't have to remove the intake manifold correct?
Old Oct 14, 2014 | 04:16 PM
Post crystal clear pictures of the connectors plugged into the IAT, ECT, and TPS. The pictures should allow verification of each sensor and show the wire colors at the rear of the connector. The IAT and ECT have 2-wire connectors and the TPS has a 3-wire connector.
Old Oct 14, 2014 | 04:19 PM
Kevin82's Avatar
Will do tomorrow AM. @RonJ
Old Oct 14, 2014 | 06:51 PM
Kevin82's Avatar
Old Oct 14, 2014 | 06:55 PM
Looks like it may be the wrong plug for the ECT sensor, though I can't see the wires clearly. Look at the diagram I posted. The plug should have Red/Wht and Grn/Blk wires.
Old Oct 14, 2014 | 07:36 PM
Kevin82's Avatar
You're correct @RonJ. Red/yellow Green/black. Different plug somewhere?
Old Oct 14, 2014 | 07:40 PM
^These are the ECT connector wire colors?
Old Oct 14, 2014 | 08:12 PM
tony_2018's Avatar
Fish Twig
I spy custom wiring............you better double check that...
also spy exposed wiring........
Old Oct 14, 2014 | 11:55 PM
Kevin82's Avatar
Yes.
Kevin82's Avatar
Oh there is plenty of "custom" wiring. This car has it all.
Old Oct 15, 2014 | 04:34 AM
Kevin82's Avatar
Sorry RonJ I stand corrected. They are red/white green/black
Old Oct 15, 2014 | 05:37 AM
tony_2018's Avatar
Fish Twig
Than you better double check for any exposed wiring, like what I'm seeing in your pictures.
