HELP ME PLASE, error code 8: TDC obd1
Hello, first of all hello to all the community.
I have a problem with my car; It is a Civic 1977, d16a9 swap (obd1) ecu obd1 p29 and branch wiring obd1 jdm h22a originally obd1, obd1 distributor Original td43u car.
Currently the check engine light throws me a single error code is 8 corresponding to "TDC Position (Top Dead Center)" ... That way I can fix this? The engine starts well but accelerates with difficulty (ralenti); i have retailers the distribuitor have to delay it too (while I remove bolts that attach the distribuitor to the cylinder head so that the point where the engine accelerates well). Check PMS and it's good any good and this draft; the only thing left is turning me if the error affects TDC tuning dealer or if it affects the distributor advance because the ecu error.
I apologize for the English but I speak Spanish.
Best regards!
Fernando
Best regards!
Fernando
Best regards!
ivanson
Dec 4, 2005 12:35 PM
