zc transmission
Old Oct 13, 2014 | 12:37 PM
J(ef)F's Avatar
Default zc transmission
Did the single cam zc tranny have the same gear ratio as the dohc?
Old Oct 13, 2014 | 01:19 PM
crxguy406's Avatar
Default Re: zc transmission
I believe both zc engines shared the same tranny, but I could be wrong.
Old Oct 13, 2014 | 01:25 PM
24TEN's Avatar
PHANTOM MENACE
DOHC had different gearing, a bit tighter gear to gear, but shared the same final drive ratio as a DX.
Old Oct 13, 2014 | 03:31 PM
J(ef)F's Avatar
Ok so that's where I'm getting confused, I have had the dohc ( bigger output shaft) tranny which had the closer ratio but have also had two what I believe to be the sohc tranny that seemed to have the same close ratio. Can anyone confirm this?
Old Oct 13, 2014 | 03:46 PM
4drEF's Avatar
Keyboard Humorist
I'm not sure how reliable this site is, but it's the USDM parts look right.
http://www.knology.net/~jediklc/gearratiosdseries.htm
Old Oct 13, 2014 | 11:15 PM
Tyson's Avatar
What does the label or any markings on the case say? Then I can confirm what you have.
trooper0641
17
Feb 5, 2017 08:49 PM
trooper0641
35
Jan 24, 2006 02:00 PM
2kTeg
Oct 21, 2005 10:04 AM
sleepingcivic90
49
Jan 21, 2005 09:55 AM
