My EG Hatch project
Old Oct 12, 2014 | 02:29 PM
tollickj's Avatar
Default My EG Hatch project
Traded my 94 Acura Integra for this 94 EG hatch. Plan on making it my track/saturday night fun car. Currently has d16z6 in it. I built an all motor lsv I will swap into the car. I put my s2000 seats in the car.
Old Oct 12, 2014 | 02:38 PM
tollickj's Avatar
Default Re: My EG Hatch project
Here is my lsv I will be swapping into the car. B16a2 head attached to my b18b block with arp head studs, pr3 pistons on ls rods with acl bearings all around. I'm still peiceing the build together. At the end of this I want to be able to safely spray this motor. I have comp 2 cams, skunk2 valves and springs ready to go into the head.
Old Oct 12, 2014 | 02:41 PM
joey1320's Avatar
Nice engine!
Old Oct 12, 2014 | 02:52 PM
tollickj's Avatar
Originally Posted by joey1320
Nice engine!
Thanks. I had the block and head sent out, to get hot tanked, and freshin up. My plans to the car is to work on the brakes and suspension first. Tomorrow my friend and I are going to the junkyard to look for rear disc brakes so I can convert them. After that its going to be the motor then all cosmetics to make the car look clean. Thinking apple red.
Old Oct 12, 2014 | 02:55 PM
joey1320's Avatar
I like your plans although I would go with the body before swapping the engine
Old Oct 12, 2014 | 03:33 PM
tollickj's Avatar
The reason why I want to wait, because I don't want to damage the new paint job on the car when I can do all the maintenance on it then won't have to worry about scratching the paint.
Old Oct 13, 2014 | 01:23 PM
tollickj's Avatar
Today was a successful day at the junkyard, picked my my rear disc brakes for $100. Thats a steal down here in Florida. People sell these for 200-250. Couldnt find a proportioning valve. I will have to order one from Honda. I am going to rebuild these, bushings, rotors, calipers, and put new pads on these.
Old Oct 13, 2014 | 01:31 PM
tollickj's Avatar
Picked up a new recovery tank too. My old one was cracked. Heres a pic after I cleaned it up.
Here is the tank installed.
Picked up a new switch, the car doesnt have cruise control but what I have now is only for the light control. And theres a gap. I rather it look clean.
Before.
How it looms now with the new switch, looks a lot better without the hole.
Old Oct 13, 2014 | 01:57 PM
tollickj's Avatar
A friend gave me this duck wing for my hatch. I also changed my mind on the color on the car and want to go white.
Old Oct 14, 2014 | 11:49 AM
tollickj's Avatar
[QUOTE=tollickj;50001256]
I just ordered replacement parts. I got new trail arm bushings, hydraulic hoses for both sides and new rotors online. I ordered new calipers at advance auto parts. Its cheaper thru them when I can eliminate that core charge.
Old Oct 14, 2014 | 12:04 PM
S!K TEG's Avatar
In for this.
Old Oct 14, 2014 | 12:19 PM
09chaplak's Avatar
Loves Tossing Salad
Duuuuuuuuuuuuude I want those seats, did you cop them from a type s?
Old Oct 14, 2014 | 12:25 PM
tollickj's Avatar
Originally Posted by S!K TEG
In for this.
Thanks!
Old Oct 14, 2014 | 12:30 PM
tollickj's Avatar
I got these seats for $300; I had to change out the rails and put Integra rails on them. They were in my Integra before I traded it for this.
Old Oct 15, 2014 | 08:20 AM
tollickj's Avatar
Small update. Advance only had rear left caliper. I picked this and the hatdware for it. Going to search other stores around to get the rear right one.
Old Oct 18, 2014 | 03:21 PM
tollickj's Avatar
Got the goods today.
Old Oct 18, 2014 | 03:27 PM
tollickj's Avatar
You can see how bad the bushing is...
Here it is after i got it out and cleaned it.
This was a b@#$+ to remove. This is what i used to remove it... still gotta do the other side.
Old Oct 18, 2014 | 03:50 PM
B_Swapped93's Avatar
You'll miss your integra, trust me they all do, good luck on this build tho man.
Old Oct 18, 2014 | 07:58 PM
tollickj's Avatar
Yea I put a lot of work into it, but I had a EJ1 before and the only reason I went into a teggy was because I fucked up my civic. Thanks bro, maybe a few years down the road I'll get another one.
Old Oct 19, 2014 | 08:18 AM
tollickj's Avatar
Isnt pretty but I got it in...
Screws were stripped. Had to drill them out.
Screws gone.
When I was at the junkyard I cut the hoses. I didnt trust them so I am just going to them.
New hose.
Removed the other bushing. I've been having trouble and was getting frustrated so I'm taking a break.
Old Oct 19, 2014 | 12:29 PM
Norlael's Avatar
haha, I bet must have been a pain in the *** to hammer those out. Next time you should try melting the center out, and then using a dremel tool to remove the shell.
then there is the method I use personally which is HF 12 shop press. you can get one of these bad boys for like $100. As many times as I've used it, that $100 was easily recovered.
nice build so far tho.
Old Oct 19, 2014 | 02:27 PM
tollickj's Avatar
Finally got it in!!! Had to sand both the metal and the busing ring. Used 40 grid and some lube and got it in nicely.
New brake line.
Screws out. Calling it a day. Need to pick up brake pads anyways and a rear right caliper.
Old Oct 20, 2014 | 07:47 AM
tollickj's Avatar
Bought other caliper today and installed it. One side done. Will finish the other one tomorrow.
Old Oct 21, 2014 | 12:03 AM
ghostz32's Avatar
luv the EG hatch
Old Oct 21, 2014 | 08:26 AM
tollickj's Avatar
Finished last one.
Installing these on Friday. I'm excited to get this done. After installing this all I need to do is to swap out the proportioning valve with an si one.
