s300 idle drops when AC or fan turns on
Old Oct 11, 2014 | 10:34 PM
99black_em1's Avatar
Default s300 idle drops when AC or fan turns on
hi, im on the hondata s300 in my 1999 civic si. the engine idles nicely at 900rpm, but whenever the radiator fan turns on, or AC is on, the idle drops fast to 500rpm... or dies. Is there something i can change in the parameters to help?
Old Oct 12, 2014 | 03:08 AM
7rrivera7's Avatar
Default Re: s300 idle drops when AC or fan turns on
Sounds like the ECU may not be compensating (A/C circuit or possible ELD). Did this happen before you installed the S300 or are you using another ECU? If you are using another ECU, if you swap in the original does the same thing happen?
Old Oct 15, 2014 | 11:32 AM
94dxcoupe's Avatar
It sounds like the ELD may be disabled within the S300 software. Try enabling it and see if it fixes it..
Old Oct 15, 2014 | 09:35 PM
VegasInvasion's Avatar
I'm Huge In Japan
most likely you have a bad ground or a failing ignition system. coil, cap/rotor, plugs, wires.
Old Oct 17, 2014 | 12:25 PM
mtber's Avatar
If you are running large injectors, make sure you are using the correct injector data.
Monitor the condition with a wideband & see if the air fuel ratios at idle are drastically
changing.
Also monitor the battery voltage and make sure its not dropping too much due to an issue with the charging system etc.
gpuck16
Honda Civic (2001 - 2005)
Aug 17, 2018 12:31 PM
Esprit09
Jun 7, 2011 03:27 PM
jken0904
Aug 2, 2010 01:23 PM
El_Arsonista
May 3, 2007 06:40 PM
srv3fender
Jun 11, 2005 06:53 PM
