H2B here we come !!!
Old Oct 11, 2014 | 05:16 PM
FMN716's Avatar
Default H2B here we come !!! PIC HEAVY BEWARE
Greetings from South Africa
Gonna go H2B so need some advise, I always do research before asking. So please help me out
Went to a local engine importer today to collect my JDM h22a motor which was about $600
Thought I post some pics
Sorry if they are blurry bad lighting
On the way home with my baby at the back - my ek became my van lol
Pics of Motor
Tried searching this but couldnt really find any info so please help me out
So my question is
here is SA this was a really good price for this motor but when I got there all the motors were missing oil caps, this place was a massive warehouse so some dust def went into the head. Should I be concerned and how do I clean it, with out removing the head
Thanks
Old Oct 12, 2014 | 01:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: H2B here we come !!!
Maybe flush it with a few oil changes idk thats sketchy! no oil caps wtf! they deff got some dirt and debri in them. Worst case is pull the head and have it inspected and hot tanked cleaned and maybe a rebuild just to be safe like a valve job and new seal ect. better to be safe than sorry!
Old Oct 12, 2014 | 02:35 PM
FMN716's Avatar
I think I am going to took off the VC couldnt really see any dust or particles
but as you said let me rather play if safe
Old Oct 12, 2014 | 02:57 PM
FMN716's Avatar
Decided to check health of the motor and found this
Plug wires 2, 3, and 4 all had the signs of water penetration in the spark plug chamber
Plug from Cylinder 4
Plug from Cylinder 1
As a note this motor does have some oxidation on it.
So I decided to remove a few brackets and parts and try to clean the block
I used
Oven Cleaner
High Pressure System
Make sure you seal all holes and dizzy
Use safety goggles and mask as fumes are strong
Apply it thick and wait full period of 15min
Did this in the front 2 times due to the heavy dirt/gunk content
Before
After - Ran out of product for the back
This was only a test next I want to remove all parts so I am left only with the cylinder head, block and sump
Old Oct 13, 2014 | 06:28 PM
Bently_Coop's Avatar
Steve at Heart
What kit will you be running?
Old Oct 13, 2014 | 09:44 PM
FMN716's Avatar
Here in SA there is a guy in CTN making a kit that consists of
Plate adapter
Extended flywheel bolts
Flywheel spacer
Mounts
he is asking about 420 usd if I had to convert to usd
Old Oct 14, 2014 | 01:51 PM
FMN716's Avatar
Guys need some advise
I want to remove my crank pulley and that f@#$#en bolt wont loosen
I have seen the trick with the starter and also the trick using a jack stand as a mount and using a breaker bar to loosen the bolt, but unfortunately motor is out and its not going in my car for some time
I tried chaining the auto flywheel to a mount hole for gearbox so the crank doesnt move and using my impact wrench (200nm) but the bolt is still tight
Any suggestions
Old Oct 14, 2014 | 02:03 PM
wunfstgsr's Avatar
Loved
Community Favorite
Any suggestions
Get a propane torch you can find them cheap at your local parts store, Also order this tool from the ebay link. Torch the bolt for a few mins then use a impact gun or the tool from ebay and a extension with a breaker bar, place a jack stand under the extension for support and break the bolt loose. You can also use this tool with a impact gun.
http://www.ebay.com/itm/50mm-Honda-And-Acura-Crank-Pulley-Removal-Tool-/321398823818?pt=Motors_Automotive_Tools&hash=item4ad4dcdb8a&vxp=mtr
Old Oct 14, 2014 | 02:43 PM
FMN716's Avatar
50mm Honda and Acura Crank Pulley Removal Tool | eBay
Ok cool thanks for the idea with the torch, will try it this weekend with the torch
Old Oct 17, 2014 | 12:42 AM
FMN716's Avatar
Build on hold because of an idiot
Old Oct 17, 2014 | 12:48 PM
wunfstgsr's Avatar
Loved
Community Favorite
AHHHH sucks dude!! hope you get it back together better than ever haha
Old Oct 17, 2014 | 01:58 PM
FMN716's Avatar
haha thanks I plan on keeping this car, so hopefully insurance scraps the car (I have fully comprehensive insurance) and I can fix the few things and do a full respray at a later stage and use the extra cash for my h2b build
Old Oct 17, 2014 | 05:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea good idea I did that a few times not as bad as that but fender benders would pay me good lol
Old Oct 18, 2014 | 02:34 AM
joey1320's Avatar
Looking at the condition of the warehouse and the way all those engines are just thrown about, I would never buy anything from them...
Good luck with your build!
Old Jan 29, 2015 | 12:49 AM
ClintonRossouw's Avatar
Post Re: H2B here we come !!!
BUMP!! Hows the build going ?
jdmwatch
Appearance Build Threads
17
Oct 21, 2014 09:26 PM
fillipo
Apr 26, 2008 02:30 PM
Rdriver
Feb 21, 2008 11:25 AM
NIKE SB'd
Feb 8, 2008 09:07 AM
newbie415
Jan 5, 2008 11:32 PM
