ZC's
The ZC engine code is ZC...hehe
The d16a1 is from the 88-89 integra. You will need the engine longblock, use your trans, and run an 88-89 integra ecu or use your own ecu. That is it. It is a very very easy swap into an Si
if your doing a zc swap into a 88-91 crx, this site is the BEST
http://dmoore.com/crx/zc.htm#ZC%20Parts%20List
It tells you everything you have to change, and a lot of stuff you should change
kshymkiw, assuming you have a 88-91 honda civic/crx si model...
If you use just the ZC motor:
-Replace the alternator (civic),
-Replace the distributor (89 integra)
-Replace the wires and plugs (89 integra)
-Replace gaskets and timing belt, waterpump (for longivitiy of the motor)
-Replace clutch (better now than later)
-Replace ECU with 88-89 5 speed or ZC ecu (better performance that the civic si)
If you use the ZC motor and tranny
-all of the above and
-90-91 intermediate shaft or the ZC shaft if it's still connected
-88-89 or 90-91 axles
As far as the wiring for the distributor, I forgot, sorry...hopefully someone here remebers...
Engine codes are the same as the 88-91 civic/crx si or the 88-89 integra...
[Modified by X, 12:53 AM 11/2/2002]
[Modified by X, 12:57 AM 11/2/2002]
krysted9354
14
May 23, 2009 09:04 PM
importlover6262
Apr 11, 2008 06:39 AM
89SilverCRX
Aug 13, 2006 03:10 PM
