A couple of things that are annoying on my car.
Old Nov 1, 2002 | 12:19 PM
integranator's Avatar
Default A couple of things that are annoying on my car.
Ok, first my hatch doesn't not stay up anymore-- maybe the hyrdo. fluid is bad or there is a leak?? Any my antenna does not come up anymore.... my cat heat shield rattles almost through the entire rev range.... and my mph needle fell off a while back-- so it needs recalibrated because the mph is off... so all in all i love my baby!!! Anyone have any remedy's to these problems?
Old Nov 1, 2002 | 12:43 PM
metal-x's Avatar
Default Re: A couple of things that are annoying on my car. (integranator)
remove the heat shield.....
Old Nov 1, 2002 | 01:28 PM
Default Re: A couple of things that are annoying on my car. (metal-x)
i've heard removing the cat shield (since its iron?) will melt somethings
Old Nov 1, 2002 | 06:02 PM
basmasta7's Avatar
my heat shield is rattling, too - it's annoying as hell. does anyone know how to fix this without actually removing it (i'm too much of a ***** to risk melting anything). i haven't been under the car yet though so maybe i could just figure somethin out when i look.
Old Nov 1, 2002 | 07:01 PM
animated_life's Avatar
i've got a whole bunch of easy fixes for you.
1. my cat heat shield rattled too, so i tried to use some JB Weld on it...which broke after a day in a half. so i tore the heat shield off and now it's great. and NO my floorboard doesn't even heat up, no side effects.
2. you can fix the hatch by going to the dealer or autozone and buying replacement hydros and installing them...$10 tops.
3. screw the antenna motor, disconnect the wires going to it and just leave the antenna up (or make a short *** S2000 antenna look-alike if you want) and your reception will be cake.
...can't help you with the speedo...but hope the other stuff helped.
Old Nov 1, 2002 | 08:40 PM
Default Re: A couple of things that are annoying on my car. (animated_life)
also-- my parking break light is always on...anyone have any suggestions?
Old Nov 1, 2002 | 08:50 PM
ingrate's Avatar
25 Year Member
the obvious answer is to check your brake fluid.. but if the fluid is full, then try removing your neuspeed strut bar if you have one..
Old Nov 1, 2002 | 08:51 PM
johnisenglish's Avatar
I also removed my cat heat shield after it rattling for months on end, and haven't had any problems yet (its been about 3 months). As far as the antenna goes, I'd either put in a switch (assuming that the motor isn't dead) to control it manually, or just leave it down (I get perfect reception with the antenna down - go figure). For the parking brake light, you could just disconnect the sensor...
Old Nov 3, 2002 | 09:00 PM
95integragsr1984's Avatar
shave the antenna,put a antenna in your dash(cost $50 to shave/primer antenna) take heat sheild off, dont be a ***** it wont heat up that much if at all, i did it on my ls and had it like that for a long time, like a year, never notice anything at all ,even on long trips nothin, so just get rid of it
Old Nov 3, 2002 | 09:14 PM
97hb's Avatar
OH NO, you got a lemon. J/K, these are problems that plague everyday h-tech personel. You must deal with them or pay stiff penaltys
Old Nov 3, 2002 | 10:35 PM
threatcon13's Avatar
New User
Default Re: A couple of things that are annoying on my car. (97hb)
take the shield off. nothing will melt.
Old Nov 4, 2002 | 08:38 AM
zilverz's Avatar
Im gonna take my heatshield off ... but as an alternative suggestion ... is to spot weld it on all the flex points .... and of course make sure its not bent and rubbing on the pipe or cat ...
otgarza
Honda CR-V & Element
Dec 4, 2012 03:52 PM
japspecjohn
Jun 18, 2009 04:43 AM
DC4 Rasta
Feb 1, 2006 09:41 AM
JonathanRuiz
Nov 29, 2004 04:32 PM
Woody_geeser
Jun 28, 2001 11:37 AM
