running without a map sensor?
Hi, is it ok to drive witout a map sensor?
My car won't stay running if the map sensor is plug in?
I only have a spare 4bar map sensor to replace it,but it still dies when plugged in.
Any ideas? Thanks
Any ideas? Thanks
I don't think your car would run very well without a MAP sensor. A 4 bar map sensor will not work at all. You would have to scale the voltage differently because the ECU is only set up for the stock MAP sensor voltage. Are you getting a Check Engine Light?
Sorry for the late respond. I got a new sensor, no check engine light, no cel, and the color of the wires are yellow/red,green/white and white? I also replace new vaccum hose.
Any other advice would be appreciated. Thank
