FS - Weldon 2345a fuel pump and controller
I am selling my Weldon 2435a fuel pump and the speed controller as well. Both are in excellent working condition. I am selling because I am going to a mechanical pump with the hopes of trying methonal. Im asking $950 plus shipping for both. The pump manufacture date was 12/06 but the pump was sent in to be checked over and refreshed last year. Since then it has 1000km of street driving and 5 passes on it.
If you have any questions, please feel free to PM me.
Weldon Specs;
Maximum Horsepower
2000 hp @ 14 VDC EFI (1000 hp on Methanol)
2400 hp @ 16.5 VDC EFI (1200 hp on Methanol)
GPH/PSI Range: 200-250 GPH / 0-80 PSI
Considerations: If your actual horsepower is close to the Max Hp limit and/or you are considering power adder, see part# 34706 or 34712 Mechanical Pump
Features
All billet body pumps are 100% serviceable/repairable
Self Priming
Pump may be mounted above fuel cell
Vertical or horizontal mount
Breakaway coupling prevents pump/motor damage in the event of fuel contamination
All internal components are 100% metallic
No plastics or composite materials. Our internal pumping elements are made of high speed tool steel and bronze. This results in the longest lasting, highest quality, most durable pumps available.
Body machined from billet aluminum
For carbureted and injected engines
Provides Consistent Performance with no fall-off in flow
Precise fuel delivery
Blades self-compensating for wear
6 lbs
Current Fluids
Weldon Pumps offer the widest range of fuel compatibility.
Gasoline - Methanol - Nitromethane - Diesel - Ethanol - All racing fuels
Weldon Specs;
Maximum Horsepower
Features
Self Priming
6 lbs
Current Fluids
CarbonEG43
Engine Management and Tuning
Feb 2, 2013 06:45 AM
