Crank pulley won't come off
Old Oct 9, 2014 | 06:09 AM
jdm009's Avatar
Default Crank pulley won't come off
I have a b16 that I tore apart and the pistons are out of it and everything but I forgot to take off the crank pulley when the engine was still in the car. I've read multiple threads but nothings helped... Just need some suggestions
Old Oct 9, 2014 | 06:17 AM
allshowfxt's Avatar
Default Re: Crank pulley won't come off
Put a stopper in the flywheel then use a breaker bar?
Old Oct 9, 2014 | 11:26 AM
jdm009's Avatar
The tranny is off and the crank is still in the engine!
Old Oct 9, 2014 | 11:34 AM
Bently_Coop's Avatar
Steve at Heart
Does you crank pulley have the hex inside it? If so you can order a power built tool for these that works pretty good.
Performance Tool W83168 - Crankshaft Pulley Tool | O'Reilly Auto Parts
If not Tom Cat was right with the chain wrench.
Old Oct 9, 2014 | 12:09 PM
NotARaCist's Avatar
I never narc'd on nobody!
Originally Posted by TomCat39
If the piston's are out of the block, I'm pretty sure the tranny is no longer connected to the block. Possibly the crank isn't even in the block at the moment.
Well, the flywheel doesn't come out with the transmission, so...
Old Oct 9, 2014 | 12:49 PM
NotARaCist's Avatar
There's webbing in the block that can be used (although I wouldn't recommend it). Regardless, the correct answer is the tool that Bentley linked, and that's pretty much the end of it.
Old Oct 9, 2014 | 06:31 PM
tony_2018's Avatar
Fish Twig
Its going to be tough but you're gonna have to have a second hand to stick a flathead into the flywheel through the flywheel cover and than do your best on the crank pulley bolt.
Old Oct 10, 2014 | 10:03 PM
jdm009's Avatar
Thank you everyone I got it off with the help of a buddy. We used a chain wrench with a breaker and extension and came off nice and easy! Appreciate everyone's input
Old Oct 11, 2014 | 03:07 AM
tony_2018's Avatar
Fish Twig
Tony my man, you really need to read the thread. The motor is not in the car, nor is the tranny attached to the motor.
It requires the honda pulley tool or chain wrench like I already mentioned and another put a link to the Honda pulley tool.
Well....the only thing I read were that the pistons were out and "everything". That could mean anything. not to mention. How does one take the crank off with the oil pump intact? Can't remove crank off engine block with pulley holding the oil pump on it. He could've done this the way me and NAR stated by jamming the flywheel, or his method of using a chain wrench.
Old Oct 11, 2014 | 03:17 PM
tony_2018's Avatar
Fish Twig
Gotta have that imagination dude........
Old Oct 11, 2014 | 03:30 PM
NotARaCist's Avatar
TomCat, you can still have an engine on the rotisserie with the flywheel installed
...unless you're trying to install an SR flywheel on a B series. Don't ask.
Old Oct 11, 2014 | 06:33 PM
NotARaCist's Avatar
That's partially true. I wouldn't jam the flywheel, even with the clutch housing installed That's just begging to shear, imbalance, or generally **** something up.
turboedsupe
Sep 1, 2008 11:20 AM
duffman1278
Jul 19, 2008 07:57 PM
methos713
May 24, 2007 05:52 PM
EgSalad
22
Oct 7, 2005 05:03 PM
flip1199
Nov 12, 2004 06:50 PM
