Skunk2 H22 manifold injector/rail problems
So a friend of mine dropped off a Skunk2 pro H22 intake manifold to see if I could help him with fitting the rail and injectors. The rail and injectors he gave me came from a JDM h22 of some sort (not sure exactly which H22). Anyhow, the injectors are too short and the rail only has 2 mounting holes instead of the manifold's 3. Even with the rail butted all the way up against the mounting stands without the factory spacers, the injectors are at least an 1/8 inch from seating correctly. With the spacers, forget it. The rail is floating in space a half inch away. The injectors don't look like the typical Honda b/d series injectors I'm used to seeing.
I found this picture on google.
http://i247.photobucket.com/albums/g.../untitled4.jpg
The injector on the right is what I have that is too short.
The injector on the left is what I'm used to.
93sidelsolvtec
Nov 26, 2008 11:55 PM
