Tube attached to antenna
Old Nov 1, 2002 | 11:20 AM
The Poopsmith's Avatar
Default Tube attached to antenna
What is that tube attached to the OEM antenna motor? I installed an s2k antenna and now it has no place to go, what should i do with it?
Old Nov 1, 2002 | 11:32 AM
au-gsr's Avatar
Default Re: Tube attached to antenna (DeeSeeToo)
its the water drain tube . stick it up yuor butt cause that's probably the only thing it is good for now
Old Nov 1, 2002 | 11:37 AM
GSR-REX's Avatar
New User
Default Re: Tube attached to antenna (au-gsr)
Fuggin' Hilarious!
Old Nov 1, 2002 | 11:42 AM
samagon's Avatar
I stuck it up my butt, but I found that it was hard to drive, since the hose didn't quite reach the drivers seat, so I removed it, do you have any suggestions on a propper implementation? and how many HP can I expect to see from this mod?
Old Nov 1, 2002 | 11:50 AM
au-gsr's Avatar
Default Re: Tube attached to antenna (samagon)
i would have to check the butt dyno on that one!!!
Old Nov 1, 2002 | 06:08 PM
Caught me on my off day...damnit.
Old Nov 1, 2002 | 06:09 PM
So its just a drain line? Where does it drain from
Old Nov 1, 2002 | 06:16 PM
au-gsr's Avatar
the antennabody to the rear left fender well
[Modified by au-gsr, 12:47 PM 11/3/2002]
Old Nov 1, 2002 | 10:09 PM
jonoknut's Avatar
sounds like its draining sumthin out of that dudes butt.
Old Nov 1, 2002 | 11:48 PM
iH8RICERZ's Avatar
NOOO!!!!!! mental images!
Old Nov 2, 2002 | 09:57 AM
Default Re: Tube attached to antenna (jonoknut)
Sounds like somebody woke up with something up their butt. Silly ******.
*dosent want to start flame war.
Old Jan 12, 2003 | 11:35 AM
IntEGNYC's Avatar
butts
Old Jan 12, 2003 | 07:11 PM
Default Re: Tube attached to antenna (IntEGNYC)
bringing it back from the dead in 03!
butts
redsidriver
Mar 4, 2011 05:39 PM
britishlude
Feb 11, 2005 12:49 PM
typer.org
Sep 19, 2002 10:10 AM
