Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Good To Use DOT 4?
Old Oct 6, 2014 | 02:23 PM
deerman2701's Avatar
Default Good To Use DOT 4?
Only reason I ask is I looked in the Owners Manual and it tells me to only use Honda Genuine DOT 3 branded brake fluid...? Didnt know if this new fluid would eat the brake lines or seals or mess with the ABS system.
Will be using ATE 200 DOT 4.
Old Oct 6, 2014 | 03:31 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Good To Use DOT 4?
You'll be fine
Old Oct 7, 2014 | 04:54 AM
AJ@tirerack.com's Avatar
tirerack.com
I will put ATE in my '14 Si. You will be fine.
ATE200 on Tire Rack
Old Oct 8, 2014 | 05:56 AM
DaveSi677's Avatar
You'll be fine
Old Oct 13, 2014 | 03:29 PM
FalkenSiR's Avatar
DOT 3 and DOT 4 are designed to be compatible/mixable. Spec-wise, why wouldn't we do this?!
skhell
Jun 24, 2014 09:54 AM
chiggin
Nov 22, 2009 06:57 AM
vabchaccord
Dec 10, 2003 03:58 AM
CivicSiRacer
24
May 15, 2003 12:03 PM
98cwtypeR
Sep 25, 2002 11:58 PM
