Main relay and starter cut relay clicking
So I tried searching that up and that doesn't help it doesn't come to a point that helps, so I've been working on a swap and I got it done and it's been starting fine and now it doesn't wanna start, when I pas "II" on the key, the main relay and starter cut relay starts to click really fast and the lights on the cluster dim out and when the relays click the lights dim with it, can some one please help
96 civic Dx, b18cr swapped, the other day I had a problem with the thermostat ground cause I accidentally painted over it and I cleaned it off and it started working the tranny to chassis are clean, and the one in the car is good too, the battery is a few months old so it's clean, and the terminals are clean also, how can you tell if the starter has gone bad?
I just took my starter to get checked at oreilly and they said it's working fine, so my next guess is starter cut relay or main relay? Cause when trying to start it doesn't crank or anything, just a lot of clicking in relays and lights on cluster dimming when clicking
What happens when starter relay is bad? Or when main relay is bad? I forgot to mention that before that happened my cousin was tightening the starter red cable nut and he accidentally touched ground and it sparked, would that have something to do with it acting up?
take a Wire a connect it directly where the grounds come out of the relay and then ground off that wire to the chassis bolt the the relay is secured on if it works then your grounds are bad anyways i had this same problem and this solved it for me!
Someone told me the motor might be locked so I pushed started it and it worked, so that means it's not locked it's something else, the IG 1 fuse is good and the battery fuse is good also, so what can it be?
keviiinnnnn
Jan 2, 2008 07:27 PM
Junkyard2000
Nov 17, 2005 12:03 PM
Junkyard2000
Jul 4, 2005 10:55 PM
wambus
Feb 12, 2004 03:09 PM
