97 civic harness to 97 Ls
As Long as the b18b is obd2 then mostly yes. A few items will have to be modified but some only matter if you're using a USDM ecu:
-the JDM engine won't have the CKF by the crank so you'll have to bypass it
-the b18b has a round style intake air temp sensor, you need to put your intake sensor into the intake arm or convert to the round style plug
-the JDM b18b won't have the EVAP purge valve
sk8board{Pete}
Nov 5, 2008 06:57 AM
JDMs1eeper
Mid-Atlantic (Sales)
11
Oct 13, 2008 05:14 PM
