Which first? Wheels or Suspension!?
Old Oct 5, 2014 | 11:24 PM
Vinde's Avatar
Default Which first? Wheels or Suspension!?
Hey guys, I have a little project i'm starting up with my EJ2 and I have a hard time figuring out which is better to come first wheels or springs.
I have decided to go springs over a full coilover due to budget and I dont really plan on changing height afterwards and I also don't hit tracks. That being said which would be better coming first?
The way I see it, lowering the suspension first gives me an idea of wheel sizes I can manage without scrubbing, but at the same time rims/tires offers the same results in a way (atleast how I see it). However, I could be very wrong so I am looking for some input on the better way to go about it.
Again, keep in mind I am not getting full coilovers, I would consider coilover sleeves that fit over the strut but as previously stated i'm not really looking to constantly change ride height all the time. It's basically going to be a one and done type deal. Inputs would be greatly appreciated!
Old Oct 6, 2014 | 01:03 AM
tony_2018's Avatar
Fish Twig
Default Re: Which first? Wheels or Suspension!?
Which is more worn out, tires or suspension?
Old Oct 6, 2014 | 06:43 AM
Vinde's Avatar
Both are in decent shape, but im talking rims and tires not just tires. I'm trying to figure which way would be the best way to get a stance started.
Old Oct 6, 2014 | 07:18 AM
TanEJ1's Avatar
<BOTH>
TanEJ1's Avatar
Get Both..
Old Oct 6, 2014 | 07:31 AM
BigJ74's Avatar
Premium Member
Originally Posted by TanEJ1
Get Both..
agreed..but if money is an issue, I'd grab the $100 set of springs first then get the wheels.
Old Oct 6, 2014 | 11:30 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Would be easier if we knew OP's budget.
Mine is in the trillions. No big deal.
Old Oct 6, 2014 | 02:10 PM
Thor294's Avatar
from experience in my trans am, springs/shocks/struts/whatever made a HUGE HUGE HUGE difference. I put vette wheels on and I just got wider tires which was sweet but i noticed a BIGGER difference from springs/shocks
Old Oct 6, 2014 | 06:30 PM
Vinde's Avatar
Well, my budget only allows for one at a time, and i'm just worried if I get springs ill have to just take guesses on wheel/tire sizes. I'm very unfamiliar with this kinda stuff as it is my first go.
From what I am gathering the springs i'm planning on getting lower 1.5 - 1.75 im guessing the 1.75 is after they kinda break in over time. Not sure. However, the issue is knowing what tires to go with. If I have to chose 1.5 or 1.75 which is a better option?
Keep in mind i'm most likely getting 15X7wheels, seems common enough and im not big on bigger size wheels, hell, i'm rocking 13's at the moment, steelies.. but 13's either way
Also, I am not the fan of the "slammed" scene. I am more so into the flush look. Deleted wheel gap but not so over the top that negative camber makes my wheels look broken
So from this information hopefully I can get some guidance with a tire size for 15X7 or maybe a slightly different recommendation based on the ride height adjustment soon to come. I also may consider 16's but 15's prefered.
Thanks guys.
Old Oct 6, 2014 | 06:42 PM
B_Swapped93's Avatar
CCW's over errrthang yo
lets B-serious here tho, suspension first or else you'll be at stock hight or bounching around on these ebay special "coils", don't cheap out on tires like I see soooo many ppl do.
Old Oct 6, 2014 | 08:33 PM
Vinde's Avatar
Thats another issue im going to have is picking a tire size, do you think 1.5 is enough to be flush? It seems my fender gap is more prominent in the front and the back is slightly lower, could be my worn out springs showing. Also if you could recommend a tire that would go well with a 1.5 lowering (if thats enough) to go over 15X7s
Old Oct 6, 2014 | 09:58 PM
EsotericImage's Avatar
Retired Moderator
you need to read this 1st
Building your Dream Car 101 - Honda-Tech
Old Oct 6, 2014 | 11:29 PM
Vinde's Avatar
Originally Posted by EsotericImage
That was a fantastic read. Thanks for sharing, I have already made a list of things I want to do with my car, granted not an interior list nor a 100% complete list, but as far as budget and small things (considering its just gonna be a mild modded DD) as the thread you linked calls it but I still got something out of it. Thanks again. Eventually i'm going to do a B-Swap but suspension work is a no brainer to get out of the way, atleast in my opinion
Old Oct 7, 2014 | 03:50 AM
tony_2018's Avatar
Fish Twig
OK..........so why are you asking us what should you do first if its a no brainer to you?
Old Oct 7, 2014 | 03:59 AM
B serious's Avatar
Civics of your vintage need to be lowered about 2.5-3" with stock sized tires before you remove all wheel gap. This is too low for stock length shocks.
A good riding spring lowers the car about 1-2" maximum. Some suggestions would be eibach pro kits, h&r sports, or Tein S techs with koni STRT shocks.
That's about $450-550, last I checked.
They'll work fine with 15x7 +40 or so. I'd use 205/50/15's. But you can also use the stock 195/55/15.
16x7 +40 with 215/45/16 or 205/45/16 should be fine also.
If you buy the wheels/tires first, the car will look funny until you lower it.
Old Oct 7, 2014 | 08:50 AM
Vinde's Avatar
Thanks for the info!
Old Oct 8, 2014 | 04:53 PM
ThomasBridgers's Avatar
Suspension, but don't just slap on some lowering springs on stock stocks; invest the money and get both. Better to do both then put on lowering springs then have to break down the assembly two months later to replace the spent stock shocks. Save yourself some labor.
Old Oct 8, 2014 | 04:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
So, mods...how is this even remotely a tech-worthy thread?
Old Oct 8, 2014 | 05:20 PM
tony_2018's Avatar
Fish Twig
Thats what I'm saying....
Old Oct 8, 2014 | 07:17 PM
Retired Moderator
yea true. its been answered.. IDK even know where I would move it to. So its closed
Blue-Civic-Hybrid
Jul 25, 2017 03:45 PM
drei2123
May 19, 2013 11:52 AM
silverlude80
Feb 18, 2011 03:45 PM
lude-tec
Suspension & Brakes
Jan 14, 2006 09:04 PM
matt0199
Dec 19, 2002 10:32 PM
