TX $$ 2000 USDM NBP INTEGRA TYPE R #00-0187 (CLEAN TX TITLE) $10,500
For Sale is a USDM 2000 Integra Type R #00-0187 clean Texas title under my name, no wrecks with 134, xxx miles. $10,500
Need it gone ASAP or will unfortunately part out
INTERIOR: All original integra Type R interior, badged armrest, OEM ITR front seats, OEM ITR rear seats, OEM ITR floor mats, OEM ITR CLUSTER OEM ITR clock, sterring wheel, shift boot and all carbon fiber trim. No spare tire, no jack, No radio or rear speakers.
Autopower 4pt roll cage (really stiff and firm)
Shortshifter and innovative shift linkage has New brakes with steel braided brake lines on all fours, spherical rear trailing arm bushings fairly new
EXTERIOR: Stock ITR body no dents, cut rear bumper for track use (will get original rear bumper with purchase and front right turn signal air intake duct), rear wiper delete, shaved antenna, white jdm ITR 16 inch wheels wrapped with bridgestone b500 si 205-50-16 (80% tread left) paint 7/10 normal wear and chips
ENGINE: stock USDM ITR P73 ECU, sleeved GSR block, hi compression pistons, Eagle rods,
JDM ITR head with ferrea valves, keepers, retainers, dual valve springs, buddyclub spec 3 cams, AEM adjustable cam gears, AEM fuel rail, USDM ITR header, on September 5, 2014 I replaced distributor, axles, battery, ngk spark plug wires with new parts, fresh oil change with Lucas Oil stabilizer as I've been doing for years. Has no name ebay cat back exhaust with innovative test pipe (sounds real aggressive not rice). Has A/C and Power Steering.
***Due to not converting the vehicle to OBD1 like I normally do, it does have a CEL for high emissions because I am using a test pipe instead of a catalic converter and the 02 is not reading properly
*** another CEL for the IACV which I changed out but it still throws the code for some reason
easy fixes but I attend to my PYR because I am keeping that one and it became a money pit
NO TRADES!!!
CASH ONLY!!!
NO WINDOW SHOPPING!!!
SERIOUS BUYERS ONLY
DONT WASTE MY TIME please
$10,500 Need it gone ASAP or will unfortunately part out.
Located in El Paso, TX
PM me if interested and for more information
txt for more pictures
915-726-2060
Thanks for looking
NO TRADES!!!
CASH ONLY!!!
SERIOUS BUYERS ONLY
915-726-2060
Thanks for looking
ANDy415
Mar 20, 2011 03:53 PM
