D16Y8 Radiator fan still not running.
Old Oct 4, 2014 | 01:13 PM
ayemaverick's Avatar
Default D16Y8 Radiator fan still not running.
Tested the cooling fan switch,cooling fan it self,and swapped out the thermostat. My car doesn't overheat for now but ran the car to running temperature and the fan is still not working.Any ideas??
Old Oct 4, 2014 | 03:50 PM
tony_2018's Avatar
Fish Twig
Default Re: D16Y8 Radiator fan still not running.
If you did pull the plug off of the thermostat housing, jumped it, and the fan still didn't come on than your next move is to check the relay in the fusebox and check the fuse while your at it.
Old Oct 4, 2014 | 05:00 PM
Originally Posted by TomCat39
So you say you've tested the fan. Are you implying that the fan ran when hard wired?
How did you test the fan thermo switch to verify that it was good?
If the car isn't overheating, then how do you know you've run it long enough to get hot enough for the fan to kick on?
If the temp gauge went over half way and no fan coming on, then I can see you stating what you are stating. At this point it sounds like the motor hasn't gotten hot enough to kick the fan on.
I used alligator clips on the radiator and attached it to the battery and it ran, second test I did was use a paper clip to hot wire the relay and fan still ran.Then I just swapped out the old thermostat had it running for about 30 min then drove it around the block and onto the freeway but I still yet see the fan kick in after parking.And is the bottom hose suppose to get hot as well??
Old Oct 4, 2014 | 05:01 PM
It worked when I put in a paper clip and put the car on "ON"
Old Oct 5, 2014 | 12:20 PM
Negative Georgia
Old Oct 5, 2014 | 12:46 PM
tony_2018's Avatar
Fish Twig
I heard its very cool weather at this time so you're not gonna get that fan to come on just by sitting in the driveway and revving it.
tony_2018's Avatar
Fish Twig
You sure as hell didn't make that step clear enough. You made it sound like everything you did the fan did not come on. DETAILS..
EJ8Squad919
Jun 30, 2014 06:46 PM
fatl13ert
Oct 22, 2012 12:41 AM
brickerj
Dec 22, 2011 02:08 PM
slow sol
Mid-Atlantic (Sales)
Sep 18, 2009 04:58 AM
mycivicisslowasfuck
Oct 25, 2004 08:51 AM
