please help 95 Accord #3 misfire
hi I,m hoping someone can help me with this little problem I'm having.
I have a 95 Accord with the V-tec with 85,000 miles and i have a misfire on the number 3 cylinder. I'm not getting a misfire code but i am getting a fuel injector code. When i first start the car it will idle ruff but after i drive 1/4 mile it wont even idle anymore. The #3 tube on the exhaust manifold doesn't heat up no were near as fast as the rest of them after start up and if i pull the connector on #3 it has on effect on the idle. So i know #3is dead. It has new plugs, wires, cap, fuel injectors, fuel injector connectors and I'm getting good spark i checked the compression and got 180psi +or- a couple psi on all four cylinders i checked the connectors with a noid light and that's good. and i do not know were to go from here if any one has any ideas i would very much appreciate it.
Check for continuity from the ground side of 3 injector back to the ecu connector. If you got continuity open up the ecu and look for burned spots. It could still be bad.
http://technet.ff-squad.com/wiring.obd1.htm
Adnneby Reynoso
Aug 11, 2016 10:20 AM
Ntense_Civic
Apr 20, 2012 04:47 PM
95CDSedan
Dec 2, 2009 02:52 PM
chokinvicts
Jan 10, 2004 07:17 AM
