89 hf s2k cluster problems help
Here's the scenario. I bought a new tucked engine harness along with a new dash harness. Plug and play s2k cluster. I've checked all wiring, checked for a bad vss. I've also ran the little test the speedohealer to see if the mph readings move and they do.
I have a question first. Even with the cluster not being calibrated the cluster should read a mph correct? When I drive the mph stay at 0. I've put in calibration other people have used and it does nothing.
I'm completely lost on this, don't know what else to check for. Thanks in advance HT
Is there supposed to be some kind of voltage regulator or a resistor that needs to be put in? I'm completely lost, and I'd really like to get this figured out asap!
Update:
So I've hooked up 3 different vss's to a drill, all with the same results.... nothing! Even tried swapping the heads on the vss and still nothing. Also checked voltage when the car was off and on. Got right at 12v with it off. And with the car running I got a fluctuating reading
jon.e.marsh
Apr 22, 2013 07:32 PM
B16Civic93
Feb 21, 2012 02:15 AM
Optik
Nov 13, 2004 07:07 AM
