Hey guys this is my first post although i have been creeping around on the website for years xD
I tried to find an answer I'm looking for but i just haven't been able to so hopefully somebody might have an idea !
One more thing is do you guys think it is worth trying to fix and or just leave it and deal with it or not ? thanks alot guys
This is the damage and. I purchased the car like this so i have no idea how it happened my real question is....how can i fix this and also while were at it out of curiousity, have any ideas on how it could have happened haha ???
just another shot of the damage
im sure all of you know how it should look but i included a pic of the side with no damage just to help
That blue was not available in the HF model, It's a DX.
OP, I would just drive it and not worry about it. That part is not structural, I would tale a look at the wheels to make sure they are centered in the wheel well. Make sure the suspension arms are not bent or damaged.
alright thanks alot everyone the only thing i have noticed is that on the opposite side the wheel is pushed back toward the door more so the caster is messed up right ?
That damage is not necessarily frame damage. As stated above it's mostly superficial. In fact, I have very similar damage on mine on the driver side but it did not impact the frame rail and the only problem on my car is it took some massaging to get the fender and hood and everything to line up. Just because it bugs me and I'm painting my car soon, I actually plan to go to the junkyard and cut-out that area from a donor car to weld into mine.
The only thing I would be concerned about if I were you is whether or not it all aligns in spec. If your driver side wheel is pushed back to toward the door something is definitely bent. Control arm, spindle arm, something bent. Assuming it does NOT align in spec (have you had it aligned?) you may want to grab suspension components for that side from a junkyard.
OR - depending on what is bent, you may be able to get it aligned within spec with an adjustable ball joint, but that just depends.
Wow okay well I am feeling a lot more comfortable and okay with it thanks a lot and I planned on replacing thing like that just wasn't sure what order I should go I guess in the end if it ends up being the last part that fixes it I have a few other new parts which is never a bad thing. Do you have any suggestions on getting the fender on good if you have ? I mean mine isn't bolted anywhere at all just held by a few zip ties I just want it sturdy and straight again, thanks a lot
I haven't had the chance to have it aligned yet either but I plan on it
Reason: Forgot to mention something
