Del Sol losing power
Old Oct 2, 2014 | 12:44 PM
masoncompton's Avatar
Icon2 Del Sol losing power
Hey guys,
I have a '93 Del Sol, with a d15b jdm motor from a '95 model, I believe. Today, after sitting in a traffic jam on the highway, my car had a sudden loss of power and would not get above around 50 mps or 2500 rpm's in 5th gear. After a couple minutes with this issue, I engaged the clutch, turn the key off, then started the car again. This fixed the problem temporarily, but it did the same thing again before I got home. As this is a project car, the check engine light has been on since I started driving it, but this problem is new.
Any and all help/advice will be much appreciated.
Thanks
Old Oct 2, 2014 | 12:46 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Del Sol losing power
This is why you fix CEL issues when they come up - you may have thrown a new code, but you wouldn't know it because you never fixed the previous codes.
Pull all CEL codes. Post them. We can work from there.
delslomt
Dec 28, 2012 01:03 PM
