Re:Civic Running Hot!
Old Oct 2, 2014 | 07:47 AM
crazed4macs's Avatar
Default Re:Civic Running Hot!
Im also having a similar issue as this thread here. Car does not overheat at idle, fan is working. Temperature beings to rise after about 20 minutes of highway driving. Flip the climate control to heat and engine temperature returns to normal. I've pressure tested the system and carbon monoxide tested for head gasket. Holds pressure and no exhaust is leaking into the coolant. Started with thermostat, changed out with 170 degree oe replacement. Problem persists. Coolant resevoir seems to get low rather quickly, and I have hot heat. Water pump? Any suggestions would be awesome. Also a 98 ex.
crazed4macs
Oct 6, 2014 06:25 PM
accord2civic2prelude
28
Dec 20, 2009 04:27 PM
xCIVICxHATCHxSI
Sep 13, 2009 10:11 PM
D16Z6_turbo
Sep 10, 2006 08:57 PM
omar256hxc
19
Dec 20, 2004 12:46 PM
