1989 honda crx wont start
Old Sep 30, 2014 | 09:11 PM
J . K .'s Avatar
Default 1989 honda crx wont start
Thank you guys for looking at my post, i hope you can help me out.
so i bought this unmodified 1989 honda crx that has been sitting in a unit for roughly 4-5 years. I bought it and towed it home. battery was dead so i replaced the battery, changed the fluids, drained the old gas and refilled with fresh gas, and changed the oil.
the problem is that the car cranks but wont fire up.
when i turn the key to ignition, the check engine light stays on solid the whole time. it never flashes and the main relay never clicks, so the fuel pump doesnt prime either.
theres no light codes being illuminated by the ecu also
so i thought the main relay was bad which was a common problem in these models. got another main relay, tested it in my friends car, but it still has the same symptoms.
so maybe then the next thing i can think of is the ecu being bad. i tried 3 different ecu's and still have the same symptoms.
i checked all the fuses and they are all good
what else can i check?
Old Sep 30, 2014 | 11:59 PM
KevinEF7's Avatar
Default Re: 1989 honda crx wont start
Have you checked for spark while you are cranking the engine? First thing I would try
I would buy a new distributor cap and rotor, spark plugs and fuel filter just out of maintenance sake after sitting so long. Only about $40-$50 to replace all
If you dont have spark, the coil is very simple to test, simple resistance check (especially since you will have the dizzy cap off while inspecting/replacing it)
Old Oct 2, 2014 | 06:11 AM
aeon117's Avatar
Does the main relay click after replacing? Should be 3 times. 1 while it turns on, 1 after fuel pump primes, 1 while trying to start car.
Old Oct 3, 2014 | 11:25 PM
bartS's Avatar
as above. The main fuel relay is the weak spot of the crx,besides the points of leakage.
You can find it on the driver side,next to the fusebox,mounted against the side of the car. I dont know the exact specs of an usdm car,but on a edm you should remove the coin box to see it.
Old Oct 15, 2014 | 02:46 AM
J . K .'s Avatar
The main relay works. Tried it on a friends car. So far I tried main relays and ecu's. None of them fixed the problem
Old Oct 24, 2014 | 05:35 PM
J . K .'s Avatar
i also have checked the grounds and they are all secure. anything else i should look for?
Old Oct 25, 2014 | 04:22 PM
aeon117's Avatar
well, the relay not clicking means your fuel pump isn't getting power. You can crank till your battery dies, and never get it to turn. I know this because a similar thing happened to me... I ran out of fuel, but indicator said it wasn't empty. Tried cranking for like 5 minutes off and on. Got a ride to a gas station, came back and put in a gallon, and started right up, lol.
Anyways. Figure out why main relay seems to not be working. Can you hear fuel pump priming when you turn to key 2? If not, then that is most likely why cranking and no start (no fuel). Follow the wires to/from the main relay. I would say you can also bypass the relay by jumping part of the plug just to test.
Old Oct 25, 2014 | 10:06 PM
J . K .'s Avatar
the actual main relay does work, but not on my car. so i am going to assume i might have an electrical problem. theres no fuel priming as stated in the very first post.
Old Oct 27, 2014 | 05:35 AM
EL2's Avatar
EL2
10 Year Member
Fuel pumps are known to go bad in 88-91 ef have u tried jumping the power wire to see if u have a good pump
Old Oct 28, 2014 | 03:43 AM
Grifty's Avatar
Go over all the fuses and make sure they're all seated properly. Have you also checked the ground in the boot?
Old Oct 28, 2014 | 04:38 PM
J . K .'s Avatar
ground in the boot? whats a boot and where is that located?
regardless if the fuel pump is out, the main relay will still click right?
Old Oct 28, 2014 | 11:19 PM
Spiff671's Avatar
See the attached file regarding the CRX main relay harness electrical troubleshooting. If you are positive that your relay, ECU, and fuel pump are in perfect working condition, it is obvious that you have an electrical issue. The file I've provided was taken directly from the FSM (Field Service Manual). I'd strongly advise that you acquire it (the FSM can be found online and downloaded for free). Makes life a whole lot easier. Good luck.
Old Oct 30, 2014 | 12:35 AM
J . K .'s Avatar
thank you very much. ill try thIS
Old Oct 30, 2014 | 09:46 PM
BiggieDaBandit's Avatar
http://youtu.be/ZP4C_B4Fxzs
Old Oct 30, 2014 | 09:47 PM
Help me
Old Nov 1, 2014 | 12:59 AM
J . K .'s Avatar
i am having the same problem with my bone stock honda crx.
it ran before being parked for 4-5 years.
it has a solid check engine light, fuel pump doesnt prime.
i know the ecu and main relay is good because i tried it on a friends car and it worked
however, following the service manual, i failed at step 7 also.
when i probe the white/blue wire and the black #2 wire with the key in the start position, i get no power.
also when i jump the #5 and #7 with a metal paper clip, i get no fuel still. the paper clip gets very hot very fast!
Old Nov 2, 2014 | 08:59 PM
Spiff671's Avatar
Che'lu,
I want to make sure I've provided you with the correct diagnostic info. Do the wire colors coincide between your car's harness along with the diagnostic info I gave you? If so, then it is indeed the right information.
If step 7 & 8 failed, you must correct the problem BEFORE you move on.
Your multimeter is your best friend in this situation.
Step 7 checks if you have a good starter signal. This means that the Blue/white wire should give you positive (+) voltage when you turn the key to start. If this does not happen, verify that the Blue/WHT wire is not broken. Test for continuity like Step 8 says.
If step 5 & 6 are good, and your jumper wire heats up on step 10, it could mean 2 things:
1) Your YEL/BLK wire is grounding to the body somewhere. This needs to be fixed. Trace the YEL/BLK wire and make sure it is in good condition from the connector all the way to the fuel pump. You may want to remove the fuel pump also and make sure the wire insulation is not broken.
2) Your fuel pump may be seized, or may have shorted internally. If the wiring is all good, you may want to take out the fuel pump and jump it with a battery to free it up. **BE SURE TO RID IT OF ALL FUEL TO PREVENT IT FROM CATCHING ON FIRE WHILE TESTING IT. AND TEST IT AWAY FROM THE OPEN FUEL TANK!!!** If the fuel pump still does not work when you jump it with 12volts, you need to replace it.
Good luck.
Old Dec 13, 2014 | 12:01 PM
J . K .'s Avatar
thanks spiff671, i just finished school this semester and finally have free time to work on the car.
Old Dec 14, 2014 | 11:13 AM
v4lu3s's Avatar
RTFM
When I got my crx it had sat for nearly 5 years. I had to replace the fuel tank, pump, filter, alternator, battery, and had to clean EVERY ground with sandpaper.
Old Dec 17, 2014 | 09:43 AM
Sheela96's Avatar
I had a similar problem in my civic. I replaced everything. relays, fuses, fuel pump, etc. I ran a wire straight from the battery to the fuel pump and it started running.
We finally concluded that I had a short from a pinched wire somewhere between the firewall and the fuel pump.
Rigged up the fuel pump in the safest way I could coming from the battery through a few fuses and a toggle switch.
Might not be legal and is definitely not advisable, but it still works.
Old Jan 5, 2015 | 05:30 PM
J . K .'s Avatar
for some random reason, the main relay started to work on my car. fuel pump didnt prime. dropped the tank and tested the fuel pump. it was dead. so i changed the pump and put everything back together now its running great. its weird that there was an intermittent main relay problem even though the main relay is working. i must have fiddled with the wires under the dash causing it to work or something. thank you everyone for your replies!
J . K .
Oct 28, 2014 07:48 PM
kacivic
Sep 23, 2008 11:44 AM
Tru_Shine
Jul 25, 2007 02:26 PM
Trevor
18
Jul 7, 2006 05:15 AM
Hype-S
10
Jan 6, 2006 01:57 PM
