1.8vti aerodeck problem
Old Sep 29, 2014 | 04:01 AM
Lewisg's Avatar
Default 1.8vti aerodeck problem
Hi all ,
I am new to the forum with a 98' civic 1.8vti aerodeck with 93k on the clock.
I have a slight problem with the way the car is running.
When i am in say 3rd gear , at around 4700rpm at half throttle the car is hesitant/lumpy almost as if I am pressing up and down on the accelerator pedal. As soon as the car is on vtec the problem goes away.
I run nitrous oxide on my car and it does it more when using gas but it stilll does it when not on nitrous aswell.
I have tried resetting my ecu and i thought it had got rid of it but it was still after a few minutes driving and I have also bridged the connector for the CEL and the light stays on solid when the key is in position 2 and then goes away as soon as I remove the bit of wire i used to bridge them. Im not sure if this means anything as i am new with honda's.
Any help would be much appreciated.
Thankyou,
Lewis
Old Sep 29, 2014 | 05:37 AM
tony_2018's Avatar
Fish Twig
Default Re: 1.8vti aerodeck problem
Check out your distributor, see FAQ section on what to look for.
AMB6316
Honda Civic (2001 - 2005)
Oct 13, 2017 07:10 AM
LuckyJDM
17
Nov 1, 2013 12:12 PM
b16balfamale
11
Jan 14, 2009 07:55 AM
JTCdudeman
Nov 12, 2003 05:16 PM
