Changing out a axle -- How To
Old Nov 1, 2002 | 09:14 AM
jond's Avatar
Default Changing out a axle -- How To
The CV boot ripped apart on one of my cars on the driverside, and I'm thinking I'm going to replace the whole axle.
My main questions are how do you get it out from where its connected to the trani? I'm guessing you have to pry it out with a big screw driver?
Also, how do you get the new one back into the trani? Do you need any special alignment tools?
Old Nov 1, 2002 | 09:17 AM
Chris's Avatar
Default Re: Changing out a axle -- How To (jond)
Pry it out...
Push it back in. passengers side will need to be "tapped" in.
The HELMS manual shows where to pry as to not damage any oil seals.
No special tools.
Old Nov 1, 2002 | 09:31 AM
sackdz's Avatar
Just remove the lower ball joint, and pry it out. It's kind of a pain, but if you're not going to be reusing the axle kick it's ***, seabass. Just don't damage the intermediate shaft/seal.
Old Nov 2, 2002 | 07:23 AM
digitalspice's Avatar
Banned
Default Re: Changing out a axle -- How To (sackdz)
Wondering on this topic too. The Helms manual states that you need a ball joint remover tool, is this not needed for a changout of the axle?
Old Nov 2, 2002 | 08:54 AM
sackdz's Avatar
Default Re: Changing out a axle -- How To (digitalspice)
I use a pitman arm puller. They cost like $12 at Autozone.
But you really don't need anything but a jack. If you put a wrench handle or some other tool in next to the balljoint btw the knuckle and lca, just jack up the suspension and it will pop free.
PS. Watch out it mite scare the pp outta you.
Old Nov 2, 2002 | 08:57 AM
ZygSpeed's Avatar
Always good to know!
oldskoolDA6
Jul 9, 2009 11:39 AM
92ehatch
Aug 16, 2006 12:59 PM
bigdogc
Jun 10, 2005 07:20 PM
Nocturnal
Oct 26, 2004 10:21 PM
phuckinilltegie
Oct 8, 2003 01:56 PM
