2004 CR-V moonroof switch question
Hi, Forum!
I have a question about the moonroof switch on the dash next to the cruise control switch. Well, okay, a few questions.
It's supposed to light up, right? Now I've seen what the switch looks like on ebay and it looks like some gentle pressure with a screwdriver and I should be able to extract it from the dash. Is that correct?
Also, it seems that the light bulb is integrated into the switch. Is it easier just to buy another switch or is it possible to open the switch up without having parts explode all over the place and just replace the light bulb?
Thank you for any help you can give me!
Bill
Bill
Once you take the switch out
Look on the side for a small circle recessed
Either blue or gray
That should be the bulb if it is not intergraded with switch
Also sometimes a sticker might be covering it
But i would go to your local Honda parts counter and they will tell you if the bulb is replaceable
Either blue or gray
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
99fbpem1
Jul 26, 2006 04:40 PM
