1989 CRX Battery light on. no start.
So to recap a little bit we bought a crx from kind of a nutty lady. She had told me that the car had a hotwire attempt done on it. Upon getting the car home i pulled the plastic from around the steering column and had a look around. all of the wiring was fine, in fact, it looked like pristine factory wiring.
We Started by simply seeing what the car would do when we hooked up the battery and turned on the key. Nothing. Except the hazard lights worked. So today we stuck a new battery fuse in (the big 60amp block one) and now we are getting power to most of the accessories and lights. progress is made.
My question now however is about what i am not getting when i turn the key. when i turn the key the battery light comes on. that is it. no oil pressure, check engine or anything else. Obviously it wont crank either. i had a look at all of the grounds i can find and they all seem OK. I suppose that my next step would be pulling the main relay out and testing it.
If anyone has any insight for me regarding what i SHOULD be looking at, that would be fantastic. Recap: power to almost everything, battery light comes on when key is on but nothing else. no clicks from anything. no start obviously.
Thanks.
Thanks.
Gwyn'sCRX1990
Oct 2, 2014 06:07 AM
92VXeg
38
Aug 30, 2007 08:15 PM
rewerbcrx
14
Aug 16, 2007 11:42 PM
1 Cam Wonder
14
Nov 17, 2004 08:21 AM
