H2B Reverse head CRX
Old Sep 25, 2014 | 09:44 PM
PPLH8R's Avatar
Default H2B Reverse head CRX
Hey everyone its been years since I have posted anything here on the forums but figured I would post up my most current project.
I haven't had my own race car for over 10 years and finally decided to get back in the game.
Build is as follows
F23 Block with H22 type S pistons
Non ported H22 Head with super tech springs and retainers
DD tech single lobe Reapers
OBX ITBs
YS1 tranny
Super single Competition clutch
QSD adapter plate
Iam about half way through building the header and will be working on the rear end of the car this weekend. Getting rid of the factory suspension and making a solid rear end with extended wheel base ala Kaisenspeed. Hope you like it !
Old Sep 25, 2014 | 09:52 PM
ef2_civic's Avatar
Default Re: H2B Reverse head CRX
Oh nice I have a h22 swap laying around wonder how u reserve the head to make more power out of it
Old Sep 25, 2014 | 10:05 PM
PPLH8R's Avatar
Reversing the head will make no extra power but I do think it will make some gains when going 120+ MPH. I just decided to try it to take on a challenge. If the car is not making the power I want then I will probably switch it back to a conventional set up. We will see !
Old Sep 26, 2014 | 03:17 AM
AllMtrRex's Avatar
Alot of homemade engineering going on. I like it! I hope that front cross-member and cable trans are for test fitting.
What are your goals with this build?
Old Sep 26, 2014 | 08:50 AM
PPLH8R's Avatar
I will be making a front cross member and I will be using a cable trans but not the one in the picture. Trans will be a YS1 big spline.
This is a race only car so iam expecting to run high to mid tens.
Old Sep 26, 2014 | 01:49 PM
2fast4u831's Avatar
I'm really 2slow
Very nice man!! Any pictures of the modifications to the head?
Old Sep 26, 2014 | 02:20 PM
PPLH8R's Avatar
Modification to both the head and block were needed. Some oil drains needed to be blocked off and a few custom pieces I had to make on my mill. I will be doing away with the distributor which greatly simplified putting the head on this way. Also running the single lobe cams means I could do away with the vtec solenoid.
If everything works out good I may start a thread on the exact mods that need to be made.
Old Sep 26, 2014 | 05:25 PM
PPLH8R's Avatar
Was able to get on the mill and program my valve cover insert today. Looks pretty sweet if you ask me!
Old Sep 26, 2014 | 09:25 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
How do you deal with the valves being in the opposite places? I'm curious at how the intake cam will still be open at the right time? Is it as simple as changing the firing order in the ecu? or is it or am I thinking too hard? Is the firing order still the same? just the intake cam on the exhaust side and the exhaust side on the intake side?
I R CONFUSED.
Old Sep 26, 2014 | 10:40 PM
PPLH8R's Avatar
Yes you are over complicating it . The pistons are turned around so the valve reliefs match the flipped head . The intake cam stays on the intake side and the same with the exhaust. The firing order is still the same too.
Old Sep 26, 2014 | 11:07 PM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
Man that "valve cover insert" is sweet! Great job thus far, I'm already a fan
Old Sep 27, 2014 | 09:55 AM
Dark_Teg's Avatar
Cool project...in for results!
Old Sep 27, 2014 | 06:07 PM
PPLH8R's Avatar
Got the rear end mostly done today with some help from a few buddy's.
We narrowed it and stretched the wheel base too.
Old Sep 27, 2014 | 06:08 PM
PPLH8R's Avatar
Old Sep 28, 2014 | 09:30 PM
KeeganBuilt's Avatar
Sick dude. Im a fan!
Old Sep 29, 2014 | 03:31 AM
whitesihatch's Avatar
I love it, fast eddys racings van is the only reverse setup that I know of stateside.
Mad props. No people it doesn't make "more" power per say. But it does have perks, its a more efficient setup.
Leaves a lot of potential for the future.
Old Sep 29, 2014 | 07:15 AM
crazes's Avatar
Moderator
this is something very interesting to see how it would work especially on a well built H. Besides some of the technology the k possess this is probably one of the best attributes when it comes to running them.
Old Sep 29, 2014 | 07:18 AM
JuggerNaut-CTR's Avatar
Subbed for ze updates. Very cool seeing these builds!
Old Sep 29, 2014 | 11:12 AM
PPLH8R's Avatar
I watched all the videos that they put up about the odyssey and can tell you that the method in which I did the swap is much different . The way I did it allows the cam shafts to be used with no modifications what so ever. Additionally no welding was needed to the block or cylinder head. It just took a little ingenuity.
Old Sep 29, 2014 | 12:33 PM
Trey's Avatar
25 Year Member
Icon6 Re: H2B Reverse head CRX
Nice work!!
The reverse head reminds me of the 90's BTCC accords.
Old Sep 29, 2014 | 01:59 PM
1991_crxsi's Avatar
wow. So much creativity, work, effort, and a pretty unique set-up. I know there are other reverse-head H22s, but I am really liking what you have done here for sure. This is really great stuff!
Old Sep 29, 2014 | 03:31 PM
PPLH8R's Avatar
My DD Tech single lobe reapers showed today. Can't wait to hear this thing idle !
Old Sep 29, 2014 | 05:39 PM
Chugger's Avatar
Man can't wait to see more progress.
Old Sep 29, 2014 | 07:13 PM
Bently_Coop's Avatar
Steve at Heart
This build looks promising. for another crx h2b.
Old Sep 29, 2014 | 09:25 PM
93egSLEEPER's Avatar
Holy duration batman. Good ****
