Torque bolt specs please
Could someone please provide the torque bolt specs for the following for a 1993 Accord f22A1 engine
Connecting rod bolt torque spec
12 and 10 mm rocker arm bolt torque specs
Thank you
Thank you
I have a 97 Accord with the F22B2 motor. For the valve rocker assembly, the 10mm bolts are 9 ft lbs, and the 12 mm bolts are 16 ft lbs. I just did the spark plug seals and needed to remove it. Not sure on the connecting rods. Hope that helps.
uberEFtuner
Mar 2, 2012 07:01 PM
ray.riddler92
Jul 27, 2011 05:07 PM
onwisconsin81
Apr 5, 2010 01:25 AM
Retep Draw
Mar 31, 2008 03:58 AM
