Number 2 misfiring?
Old Sep 25, 2014 | 02:30 PM
Dawit DT's Avatar
Default Number 2 misfiring?
Hello wonderful people. If you don't mind I have a question for you. I have 1994 Accord and misfiring like crazy. I have changed everything like Plugs, Wires, Cups, Rotor button, and all four of the fuel injector and still number two will not spark or it has a low spark. I'm kind of frustrated, and the only thing I haven't changed is the Distributor, do you think it could be the distributor, or something else?
Thanks.
Old Sep 25, 2014 | 10:02 PM
holmesnmanny's Avatar
Default Re: Number 2 misfiring?
Spark problems in one cylinder can only be the cap, plug, or wire.
Considering you changed all of those things already, are you certain the issue is spark ?
Old Sep 26, 2014 | 11:43 AM
Dawit DT's Avatar
I can assure I have changed all of them, in fact the other day I pulled the spark plug to see, it looks burned and black substances around it.
Old Sep 26, 2014 | 06:20 PM
Old Sep 26, 2014 | 09:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Check for actual spark.
And to a compression check on the engine.
Hugo Montes
Mar 13, 2012 08:46 AM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
aziaticvang
Jul 19, 2008 11:10 AM
godnf8
Mar 30, 2007 11:56 AM
