Turbo
Hello all I recently bought a hole kit to turbo my f22a1 stock engine with its a all god speed component box has 63ar turbo with manifold with 38mm waste gate has manual boost controller and oil cooler kit, has oil line kit for turbo also got a 27x5 intercooler. was just curious as to what size down pipe I need to run this is my racecar not a street car. and what lb of boost I need to pull to make 250-300whp Possibly more im not sure as to what my limits is but I really have no budget. also replacing my injectors with 410cc have done enough research to find out that the injectors can not produce enough fuel to pull this. its all t3 stuff. Also considering changing fuel pump over to the walbro 255lph pump. Just need some opinions on size of down pipe and boost range to run this motor on.
loving the sound of 7psi to 10psi.
