CA 1997 Acura Integra K-Swapped tons of extras!
1997 Acura Integra GS
Clean Title
170k on chassis
Registration till next year
Vouge Silver Metallic
Clean interior aside from seats. Still have oem floormats and trunkmat.
Motor and trans has matching, clean vins.
Excellent Stealth security system, details given to new owner.
Engine:
-K20a2 with jdm k20a pistons and z1 cams.
New seals throughout motor, new ngk laser iridium, fresh castrol and k&n oil filter.
Also new OEM water pump, OEM headgasket, timing chain, and tensioner.
-Arp head studs
-RBC manifold
-Ktuned intake manifold gasket
-Ktuned silicone radiator hoses, oil cooler hoses, and recirculation hose.
-Ktuned Heater hose block offs
-Ktuned braided booster line
-Rcrew fuel rail with aeromotive FPR
-Rcrew header
-Karcepts ac/ps delete
-Karcepts TB spacer with TB cruise control delete
-New denso oxygen sensor
-Hasport billet mounts
-Koyo full aluminum rsx radiator
-Powdercoated VC w/ pwjdm kevlar coil cover, skunk2 oil cap and black oil dipstick
-Tucked engine harness with built in charge harness
-Hybrid racing conversion harness
-Hybrid racing ground kit
-Hondata KPRO v2 (made 248whp and 172wtq but needs retune, acc. deleted it)
Drivetrain:
-K20a2 trans w/ lsd and 4.7 final drive
-New axle seals
-Mtec race shift selector springs
-Exedy stage 1 clutch kit
-new oem fluid
-s2000 master cylinder
-Ktuned clutch line
-Ktuned billet cable mount
-Ktuned RACE spec cables
-Ktuned billet shifter stops
-Ktuned BILLET Rsx Shifter Box
-New axles
Suspension/Steering/braking:
-Skunk2 PRO-C 12way adjustable coilovers
-15" VW BBS wheels
-Energy suspension bushings (not yet installed)
-MOOG inner/outer tie rods, ball joints, and upper control arms.
-Drilled and slotted rotors front and back with PFC pads in front, OEM in back.
-ABS delete
BADS:
-Front seats are very jacked up. Dried up leather.
-Needs a tune, running on a modified basemap
-Paint is oxidizing, and needs lil bodywork here and there. But not too bad and all body parts have matching vins
Asking 7,000 Firm
I have reciepts for most of the stuff, theyre all fairly new and just finished the swap a few months ago.
May take trades for other cars plus cash.
Located in San Dimas
626 848 1888
Clean Title
170k on chassis
Engine:
-Arp head studs
-RBC manifold
-Rcrew header
Drivetrain:
-New axle seals
-new oem fluid
-Ktuned clutch line
-New axles
-15" VW BBS wheels
-ABS delete
BADS:
Asking 7,000 Firm
626 848 1888
Spend $50-100 and replace those front seats with anything else.
I'm sure you spent a lot of money on the car and I"m not sure why you neglected the easiest thing to replace.
OP don't even bother with them, like you said they are not buyers, seats are no big deal, they wont turn away a real buyer, the motor and car looks clean. Anyways when did you have the swap done. Thanks
And i finished it a few months ago. Runs strong, excellent and fun to drive.
ceepandas
Oct 7, 2014 06:19 PM
