NY 1990 CRX Si
I'm testing waters on selling my CRX. I bought the car 6 years ago in almost stock condition. The car has never seen a winter and has barely seen any rain. There has never been any rust on this car. I have no reason to sell it, but am just looking into getting something different.
-JDM B16A SiR II Motor
-Blox "Type R" Intake Manifold with port matched Omni Power 68mm Throttle Body
-ARP Headstuds with NEW Honda Headgasket
-PLM Hytech Rep Header
-RSR Ex Mag Catback
-Quaife LSD
-Brand New Axles
-Rywire Tucked Engine Harness
-AEM Fuel Rail
-AEM Fuel Pressure Regulator
-Walboro 255lph Fuel Pump
-P30 ECU (Chipped)
-Innovative Mounts
-Hasport Shift Linkage
-K-Tuned Fully Adjustable Shifter
-MPC Motorsports Shift ****
-Sonem Hydro Conversion
-Exedy Stage 1 Clutch
-Rywire Tucked Radiator with Custom fan shroud holding 2 8" Fans
--16an Radiator hoses with remote mounted filler neck
-Rywire Overflow Tank
-Mishimoto Thermostat
-Odyssey Battery
-Mugen Gen 1 Oil Cap
-DOM Tubing 6 point cage with door bars
-SiR Gauge Cluster
-Status Racing Seat
-Planted Side Mounts
-350mm Personal steering wheel (leather and yellow stitch)
-Checkerd sports steering boss
-OMP Harness
-AEM Wideband
-CRX SiR Brake booster and master cylinder
-Rywire Brake Tuck Kit
-Hawk Quiet Slot Rotors and Hawk Pads
-New Wheel Bearings
-ARP extended studs all the way around
-D2 Coilovers
-Skunk 2 Rear LCA
-Skunk 2 Rear Camber kit
-New Trailing arm bushings
-Energy Suspension Front LCA Bushings
-Stock Sway Bars
-Innovative Traction Bars
-SiR Front End Conversion
-Lexan Sunroof Plug
-Password JDM Fenders
-SiR Side Markers
-Password JDM Bumper Ducts
-OEM Antenna Block off
-Painted in 2011 (has some chips from driving)
-Enkei 92 Wheels
-TOYO Proxy R1R's
The car can be sold without the wheels, motor, etc. Just throwing the car out there. $10900 OBO
THANKS FOR LOOKING
-RSR Ex Mag Catback
-Quaife LSD
-Brand New Axles
-AEM Fuel Rail
-P30 ECU (Chipped)
-Innovative Mounts
-Odyssey Battery
-SiR Gauge Cluster
-Status Racing Seat
-OMP Harness
-AEM Wideband
-New Wheel Bearings
-D2 Coilovers
-Skunk 2 Rear LCA
-Stock Sway Bars
-Lexan Sunroof Plug
-SiR Side Markers
-Enkei 92 Wheels
-TOYO Proxy R1R's
THANKS FOR LOOKING
Any reasonable offer. Will sell without wheels and other parts to lower cost. Also willing to sell the shell with brand new hasport k swap mounts for the right price.
Whats the cost of removing the roll cage and restoring the interior to stock?
Are YOU serious? Id pay 13k for the right crx, however, I wouldnt go higher than 7k for this one and thats only if all panels are straight and the paint and weather stripping are good.
HONDAlover369
Aug 2, 2010 10:18 PM
