Replacing manual passenger seat with power accord seat in 2004 Accord EX sedan
I have a 2004 Accord EX sedan. The car came with a power driver seat and manual passenger seat. I have picked up a power passenger seat out of a 2003 Accord sedan that had been wrecked. Whats the easiest way to install this seat in my car to get it to work properly? ANY HELP IS APPRECIATTED. thanks.
You essentially need to hook up two power wires and two ground wires. For the power wires, you can run them to the under-dash fuse box, and then use something like an Add-A-Circuit.
Located at the right side of front passenger’s seat, is the 12-P gray connector.
• Power seat (REC): Terminal no. 2 – Wht/Blk wire to Under-dash Fuse No. 13 (20A)
• Power seat (SLIDE): Terminal no. 8 – Wht/Grn wire to Under-dash Fuse No. 17 (20A)
• Ground: Terminal no. 4 – Blk wire to ground (G602) (hole for a ground bolt may already be available on the passenger side floor, in front of location of rear O2 sensor connector).
• Ground: Terminal no. 10 – Blk wire to ground (G602)
http://www.google.com/url?sa=t&rct=j...,d.aWw&cad=rja
I am assuming the wiring are already there and connected from the passenger switch 12-P connector to the two motors (slide and recline)?
Ohrick
Oct 21, 2017 12:44 PM
i drive a honda
Apr 4, 2009 07:08 AM
DefendentOfHate
Jul 2, 2005 05:22 PM
