1989 crx si LSV swap help!!!
Alright so I have an 89 crx si with an lsv. It's all stock besides bolts on. I'm to the point where I'm trying to get it started. It's getting fuel. I replaced the main relay. The fuel pump is priming. New battery. Good cables. My grounds have been checked and are goood. It has about 12.3 volts getting to the starter. All fuses are good. I've tried 2 different starters. Nothing works. Basically after I turn the key 2 clicks go prime the fuel pump, I go to turn it and try to crank the engine, it does nothing. It doesn't click or anything, it just stays silent and that's it. Idk what else to try. Someone please help
If you supply power DIRECTLY to the starter itself, not on a wire anywhere else but straight power to the starter terminal, it will bypass any neutral safety switch, relay, etc. As soon as power touches the starter terminal (granted the ground is good) it should spring to life. Check the ground. It should run directly to the negative terminal wire on the battery. then connect a power wire straight from the battery and touch the starter positive terminal.
riddick5
Aug 11, 2014 02:10 PM
joshaltizer
Sep 1, 2011 07:49 PM
grass
Mar 22, 2010 06:47 PM
CoreyR
Sep 2, 2004 08:03 PM
