98 Accord Clutch Jitter
Old Sep 22, 2014 | 05:03 PM
jschamberlain's Avatar
Icon2 98 Accord Clutch Jitter
My 98 4 cyl 4 dr has 335,000 proud km on it, but just started a bit of clunky jitter on downshifting. I've always double clutched anyway, since I got the car at 247,000, but after it started shuddering, I tried downshifting without double clutching and it won't. Can anyone tell me whether this is the clutch or the transmission? Its been a great car, my son had it before me! and I have replaced wheel berarings and an exhaust system recently. I really hope I can either nurse it to 400kkm or can turn it over to someone who'd like to hot rod it.
John
Old Sep 23, 2014 | 07:38 PM
holmesnmanny's Avatar
Never experienced this before but i suppose it could be your flywheel showing its age, if not clutch-related.
Old Sep 23, 2014 | 11:30 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 98 Accord Clutch Jitter
If you have never been able to shift without double clutching then there may be other issues with the transmission, worn syncros, or possibly a clutch that does not fully release.
Any recent work done?
When was the last time you bled the clutch MC/SC?
Is the linkage to the clutch properly adjusted/with-in spec?
Old Sep 25, 2014 | 06:43 AM
Rosie Newt's Avatar
Default 98 Honda Accord clutch cylinders M/S replaced, now car shudders when brakes applied.
John
My 98 Honda Accord recently had both master and slave clutch cylinders replaced, and transmission fluid was also bled.
Immediately after this, my car shudders when I apply the brakes.
Is there a connection, and if not, what is the problem?
lsvtec101
Transmission & Drivetrain
Feb 15, 2009 03:10 PM
401tuner
Jun 29, 2007 08:51 AM
5lugcivic
Apr 20, 2007 07:13 PM
9LsTurbo1
Oct 15, 2006 11:43 AM
tekraid
Aug 17, 2003 06:18 PM
