window problem!!!
Old Nov 1, 2002 | 07:51 AM
chron1k2001's Avatar
Default window problem!!!
Last night my girlfriend decided to roll the window up and she rolled it up too hard and broke the handle Can i get this fixed at the dealer or can i get the handle from the junkyard. Is it hard to put on?????? sorrry if this is easy to do. IM still learning here. thanx
Old Nov 1, 2002 | 07:57 AM
No More Civic's Avatar
Default Re: window problem!!! (chron1k2001)
It's easy to fix. You should go to a junk yard and get one yourself. It will be alot cheaper than going to the dealer and having them rplace it.And it's not hard to do at all. Since I'm assuming you don't have a tool to pull the handle off, just take a flat head screw driver to the junk yard when you go and put it under the handle in between it and the trim piece and turn it sideways to pop the handle off.The only thing you have to watch out for is 1) losing the little metal clip that holds it on 2) breaking the handle where the metal clip attaches to. Hope that helps out.
Old Nov 1, 2002 | 07:58 AM
STK B16's Avatar
try.. http://www.hondaautomotiveparts.com
Old Nov 14, 2002 | 03:24 PM
STK B16's Avatar
Default Re: window problem!!! (Json79)
i got extra handles.. what color u need hehe
killaj12
Jul 11, 2006 07:04 PM
billedoc
May 17, 2006 12:19 PM
KillerElfboy
Mar 29, 2006 05:15 PM
asianspec
Jan 7, 2005 11:22 AM
SlammedHatch90
Jan 31, 2003 03:49 PM
