Honda CR-V & Element 2WD & 4WD Element & CR-V
Low profile intake manifold vs high
Old Sep 20, 2014 | 06:22 PM
fajnyruben's Avatar
Default Low profile intake manifold vs high
I need to replace my b20b in 2000 crv. I am browsing ebay and I see lots of high intake manifold engines for sale, while the low ones are more expensive. Why is that ?
Would the high one fit my CRV ?
Originally I had the low profile mani, but if the difference is minimal I would get the cheaper option.
thanks for help
Old Sep 20, 2014 | 10:10 PM
NZ-DB8R's Avatar
Default Re: Low profile intake manifold vs high
If they are JDM then some (not all) of the low profile IM versions are the higher compression engines known in the US as a B20Z (JDM are all stamped B20B).
High profile IM are all lower compression
The high comp engines can be identified by a knock sensor
Old Sep 21, 2014 | 08:40 AM
tony_2018's Avatar
Fish Twig
thanks for help
To really answer your question yes the tall intake manifold will fit the 1st gen crv's. If you google around you'll find images of crvs having the "giraffe" manifold.
Old Sep 22, 2014 | 11:39 PM
fajnyruben's Avatar
thank you! That helps a lot!!!
AGENT 99
Mar 4, 2025 12:41 PM
Matthew98DX
Oct 26, 2016 08:08 PM
b18cuk
19
Jul 4, 2009 09:19 AM
0260MOTORSPORTS
Oct 12, 2006 08:31 AM
