noob question, cat doesn't slip into flange, can I still weld it?
Old Sep 19, 2014 | 09:56 AM
ingrate's Avatar
25 Year Member
Default noob question, cat doesn't slip into flange, can I still weld it?
The exhaust flange is 2.5" ID and the spun cat is also 2.5" ID with 2.625" OD.
I don't have any spare 2.5" tubing lying around to slip into the flange and cat right now, if I just sit the cat on top of the flange and weld will that be strong enough?
Old Sep 20, 2014 | 05:01 PM
eithegreat's Avatar
Default Re: noob question, cat doesn't slip into flange, can I still weld it?
Maybe if it is welded really well by an experienced welder. It'll probably crack at or near the weld though. The better option may be to use an expander and/or slit the flange to fit. I'd personally wait until I could get a piece of tubing to fit right.
Old Sep 21, 2014 | 04:24 PM
para pat's Avatar
Seriously????.......
It would be just like any other exhaust butt weld. Line it up and weld it on.
Old Sep 22, 2014 | 10:36 AM
Pro-SeriesFab's Avatar
x2.
I wouldn't be scared of a butt weld on exhaust
Old Sep 22, 2014 | 11:03 AM
that-guy's Avatar
just make sure you have good penetration, and that the exhaust is still rubber mounted so that the vibrations don't cause the weld to crack
Old Sep 22, 2014 | 11:12 PM
ingrate's Avatar
25 Year Member
Thanks for the tips guys, it's my first time welding something besides scrap so I just wanted to make sure I wasn't doing something stupid.
Butt welding the flange seemed like a bad idea at first, but in retrospect it actually seems stronger than a fillet weld on the slip joint.
Old Sep 26, 2014 | 06:55 PM
95_s14's Avatar
If you trust your welds it SHOUlD be ok if not bring it to a professional welder
jxkim89
Aug 17, 2006 11:42 AM
BlueShadow
Welding / Fabrication
May 20, 2005 06:35 PM
b18c4door
Oct 12, 2003 06:43 AM
xci_ed6
Aug 19, 2002 06:17 PM
BSQ
Jul 13, 2002 11:48 PM
