Aftermarket distributor any good?
Old Sep 19, 2014 | 09:54 AM
eg:R's Avatar
Default Aftermarket distributor any good?
My distributor is breaking up in the upper rpm at times. Can this be a coil or ignitor problem ? Or should I just get a new aftermarket distributor ? I was thinking about another used oem but they are all 10+ years old units.
Old Sep 21, 2014 | 09:28 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Aftermarket distributor any good?
USUALLY higher rpm stumbles are the result of a bad coil. But I guarantee nothing with out testing.
With that said,Id buy new aftermarket.
Old Sep 22, 2014 | 01:08 AM
slowcivic2k's Avatar
Need to know what you drive. 4.6 and 5.4 Ford Tritons are known for this problem.
A stumble is the result of one and perhaps two cylinders misfiring. This will usually produce stall-like conditions. In the situation you bring up, it sounds like you have a single cylinder break up, which could mean anything after the coil itself (since the others would work).
The causes tend to be numerous without more information.
Old Sep 22, 2014 | 02:26 AM
HondaPartsHero's Avatar
Technical Hero
Year, make, model, ecu, mod, last tune up, Check engine lights?
Old Oct 8, 2014 | 07:24 PM
4drboostking's Avatar
Aftermarket distributors are usually junk. They maybe ok for a stock engine but tuning with one is horrible. The cam/crank sensors are noisy, the coils are weak and fail at the slightest temp. They suck.
DRAGANDB1
Aug 9, 2018 06:19 PM
AndyD
Dec 22, 2014 03:13 PM
B16Turtle
May 28, 2009 01:03 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
b20vtech
Dec 23, 2005 10:38 PM
