Broken
Old Nov 1, 2002 | 07:01 AM
88'CRX'Si's Avatar
Default Broken
I was driving on snow. I turned but the car didn't. It wouldn't slow down either. I was going about 10 mph and hit a curb with my wheel turned. I got out and checked and my wheel is tucked all the way back against the wheel well. It feels like there's only power to one wheel... What's broken? Axle?
(92 Civic hx)
Are they hard to replace?
Old Nov 1, 2002 | 07:03 AM
89 CRX SI's Avatar
Default Re: Broken (88'CRX'Si)
snow..... holy ****. that sucks.
ummm ok well theres a good chance your axles fin but your LCA is prolly screwed. get the manual take it a part andything bent replace
Old Nov 1, 2002 | 07:22 AM
Lord Quaalard's Avatar
Did the same thing in my beater Grand Am (R.I.P ). Sorry it happened, time for damage control now.
To answer your question, sort of, not as hard as you would think. Just take your time and you'll be ok.
[Modified by MrDyrten, 8:24 AM 11/1/2002]
Old Nov 1, 2002 | 01:13 PM
88'CRX'Si's Avatar
Default Re: Broken (MrDyrten)
Would my LCA be the reason my wheel is pushed back?
thnx for the time...
Old Nov 1, 2002 | 01:18 PM
XrcR6's Avatar
Yes, if its just a little bit pushed back. Could also have bent the hub if its a little bit farther back, if its alot then the radius rod might have snapped (or the two bolts that hold it to the lca did). And of course any combination of the above could be damaged.
Re, the power to one wheel thing... check the outer cv and hub, either disconnected or broke.
[Modified by XrcR6, 2:20 PM 11/1/2002]
BIGef
Jul 12, 2013 10:13 AM
crxaddikt
Sep 14, 2006 09:27 AM
Spo0NFed E M 1
Suspension & Brakes
May 19, 2006 06:16 PM
boostin4door
Feb 14, 2004 12:00 PM
wreckedagain
Jan 23, 2002 06:13 AM
